1966 Mustang trans fluid
Hi there...
I normally stick to the S197 forums but I ventured over here to ask for help on my grandfather's '66 coupe! Does anyone know what trans fluid the car originally takes? what grade an all? It's been so long, he forgot, and doesn't have the manual! I just don't want to ruin the trans
![]() "Never before has a 12 second car looked so mean and intimidating. Bring it." ![]() Go to www.fquick.com/americanmuscle255 for all info as well as videos! |
48.47@ 12.58
RTF I believe
it uses type f if avalible.if not,dextron 3.
i sixing 200 six with 300 hp. |
Classic Moderator
Nobody has the manual anymore, but you can buy copys of them.
Classic Mustangs are the best! Get one. |
doesn't royal purple make a tranny fluid, that works and mixes with all? But there products are pretty expensive...
yes they do,but like you said,it is expensive.i have been useing the havaline dextron 3 with no problems.
Thats what I use in mine, but pretty much any dextron 3 will work no matter who makes it. I guess it's just a personal choice.
you got it.
48.47@ 12.58
I believe it's either or.
and also that you shouldn't mix the 2 different types.
you can mix diff types,not diff grades.
48.47@ 12.58
^ that's what I meant.
thanks for the input guys. Got the fluid, filled her up...
here's where the shitty part begins. I try to start the car for the first time in a year...(my grandfather's too old to work on it by himself...) and finally after 10 minutes of priming and dieing...it coughs to life and starts running smoothly on its own...which in itself is a feat. (last summer it would die after you released the gas...) So we're both excited cause the car might actually leave the garage for the first time in 3+ years under its own power and we're like "ok! sweet! lets turn off the car (by key...yes!), put more tranny fluid in (cause only 1 quart was in at that point), then turn her back on, check the level, and finally drive it. well. When I went to turn the key again, there was a loud 'click' and the key just turned in the tumbler. just spinning. like...just turning... :lala :lala "this can't be happening...no :lala no :lala NNNOOOOO!!!!!!!!!!" I'm going back on monday after he buys the part to fix the damn thing.
Classic Moderator
Is the motor turning over?
no the actual assembly inside the tumbler broke. but we got the part so it'll be fixed soon
Threads Similar to: 1966 Mustang trans fluid
| changing trans fluid with royal purple | 01dutchGT | 99-04 | 4 | October 22nd, 2007 11:55 PM |
| this is why you should check your trans fluid guys.. | droppedbass87 | 96-98 | 8 | August 12th, 2007 05:46 PM |
| What Kind Of Trans Fluid For A T45 | wolffer | 96-98 | 2 | September 12th, 2006 09:31 PM |
| how much trans and diff fluid | militarygt | General Tech | 8 | July 23rd, 2006 01:08 AM |
| Trans Fluid Dip Stick | tllgdlkng | General Tech | 7 | July 4th, 2006 04:15 PM |
