oil change
Old August 9th, 2007, 08:59 PM   #1
pfman is on a distinguished road
oil change
I am about to change the oil in my K code 64 1/2 mustang, what oil would you suggest I use?
Old August 9th, 2007, 09:35 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
any major brand is fine. There's no need to run a synthetic in the older engines, and I always run SAE30 in the older engines as well.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old August 10th, 2007, 07:13 AM   #3
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Why do you run a 30w and not a 10w-30?
Classic Mustangs are the best! Get one.
Old August 12th, 2007, 02:01 PM   #4
Grimmy is on a distinguished road
Send a message via Yahoo to Grimmy
Personally, I only use synth in my baby.
Originally Posted by BWAL09
*gets down on knees*
grimmy, will you show me your cockle?
Official MM Zeppelineers. Crew member #1 - Captain
Old August 13th, 2007, 05:20 AM   #5
Spiderz's Avatar
1965 Coupe, 351w
Spiderz is on a distinguished road
Send a message via AIM to Spiderz Send a message via MSN to Spiderz Send a message via Yahoo to Spiderz
I use that Valvoline high mileage for mine because my 351 came out of an old LTD and I know it had a few miles on it. It seems to be running fine. They say it took over to years to develop and it can improve gas mileage by 2 miles per gallon. In my car I don't know if thats true but like I said I don't have any problems with it.
Old August 13th, 2007, 10:25 AM   #6
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
I've had two different engine builders tell me not to run multiviscosity oils in them because they weren't designed for it. There was no such thing as multiviscosity then. I take their word for it because I figure they know better than me. They both told me it can cause your engine to burn oil.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old August 13th, 2007, 07:07 PM   #7
huh, I never thought about that.
Old August 14th, 2007, 07:27 AM   #8
Classic Moderator
I would like to know how. They have all the same parts.
Old August 14th, 2007, 12:28 PM   #9
Spiderz's Avatar
1965 Coupe, 351w
Isn't oil's job to reduce friction on engine parts, in turn reducing wear on them making them last longer. I would like to think that the newer oils have more technology put into making them and do a better job of this.
Only thing I ever heard about oil weights is you should never go down a grade but you can go up. Ex : you can go from 30w to 40w but should not go from 40w to 30w.
Old August 16th, 2007, 07:00 AM   #10
Classic Moderator
I was thinking that the 302 in 1968 was just about the same as the one in 1980. I think its safe to use 10W-40 in you stang.
Old August 16th, 2007, 04:16 PM   #11
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
i use 30 wght in my mower,and 10w40 in my mustang.
i sixing 200 six with 300 hp.
Old August 17th, 2007, 10:59 AM   #12
Kobra Killer's Avatar
Kobra Killer is on a distinguished road
When single weight oil heats up it thins out and doesn't lubricate as well. During a hot summer they used to use 30-40w and in winter 10-20w. Multi-viscosity oil has an additive that prevents this. That way you can use the same oil winter & summer. If you drive your car hard most of the time, or live where it gets very hot +100*, use 10w40. If not, use 10w30.
Clevelands Rule
https://home.comcast.net/~jimmiephil...er_project.htm
Threads Similar to: oil change
how do i change my ip nba1341 The Clubhouse 1 August 13th, 2007 11:17 PM
oil change JASonic V6 Mustangs 21 July 14th, 2007 07:04 PM
change it up kaizerdan Visual 12 January 11th, 2007 07:15 PM
name change QuEeNiEsTaNg V6 Mustangs 1 December 17th, 2006 08:37 PM
