holley carb
i am trying to install a holley 570 cfm 4bbl street avenger carb on my 1965 coupe equiped with a 289. the electric choke requires 12 volts. i know these cars originally came with a choke that opened from the heat the exhaust manifold made. but i also know that there has to be a way to get 12 volts other than the battery. also many other mods require 12 volts such as an msd ignition box. so if anybody has any knowledge on this issue any ideas are greatly appreciated.
jump a wire from the positive side of your coil.
i sixing 200 six with 300 hp. |
is it a common problem not to be able to find a 12 volt wire or is there somethin wrong with my electrical system? is something is wrong any fixes?
Classic Moderator
Run a wire from your battery.
Classic Mustangs are the best! Get one. |
cant come from batt.it will stay hot all the time and kill batt.most choke systems come off same circut as coil or alt.
Wire to coil is usually about 9Vdc. I believe For uses resistance wire for the coil. You need to add a 12Vdc wire from the fuse box to the choke that is switched on & off with key in run position. You will also have this problem if you go to aftermarket coil & ignitions (like MSD)
oldeer style ford coils and same year replacement had built in resisters.i have never had a problem hooking to them.later years and after market are a diff story.you are right
I do have an aftermarket coil and distributor. Both are MSD. Are you saying that i can just change the wires? I'm sorry but i dont understand what you are saying. Thanks for the hep
look under your dash and find the fuse box.take a test light and find a single connecter that is on and off with the key.it should be 12 volts.hook to that .
Alright I've found a switched 12 volt fuse. If I hooked up an ignition box from MSD would that blow the fuse or would it still function fine?
Classic Moderator
What amp is the fuse and how much amps does the MSD draw? How much amps is the fuse drawing now?
Threads Similar to: holley carb
| Holley carb help! | JONJON | 5.0 Mustangs | 4 | October 27th, 2007 09:54 PM |
| holley intake | cali 5.0 | 5.0 Mustangs | 8 | April 20th, 2007 11:54 PM |
| Getting a Holley 750 Carb | GTXRacing | General Tech | 24 | May 12th, 2006 01:59 AM |
| New Holley Red Pump On!! | GTXRacing | General Tech | 7 | April 28th, 2006 01:56 AM |
