Backup switch
I have a 67 mustang that the back up lights don't work I have checked the bulbs and as much of the wiring that I can. I'm thinking that the switch is bad but I 'm not sure where it is located and how to remove it.
auto or stick?
i sixing 200 six with 300 hp. |
it is a auto with the i6 if it makes a difference
backup switch should be on trans.
I looked but I really could not trace the wire down to it...
If its an auto wouldnt it be internal? I have a 3spd and mine is mounted to the trans and when you click it into reverse the stick hits the plunger and there you go
i will check when i get to the shop tomorrow.
backup switch should be on shift shaft comeing out of trans.
thanks I'll check it monday. I got to put a new gasket on the tranny and change the filter I'll look then.
still no luck on this.
HELP!!!!!!!!!!
Threads Similar to: Backup switch
| Switch exhaust | Bayouboy4.6 | 2005 - 2010 | 9 | July 23rd, 2007 08:51 PM |
| trans backup switch ?? | 89Domindart | 5.0 Mustangs | 3 | January 5th, 2007 11:25 PM |
| WOT switch question | thewayshemoves | 99-04 | 4 | December 17th, 2006 09:02 AM |
| ignition switch or what? | 97TunedMustang | 96-98 | 2 | November 24th, 2006 06:53 PM |
| Installing Keyhole Backup Camera | theeipi | V6 Mustangs | 0 | November 15th, 2006 10:29 AM |
