Classic Moderator
Aluminum Flywheel?
What should I look for in an aluminum flywheel? What are other people using and what do they think about them? What are the good points and what are the bad points? How safe are they? How heavy is the stock flywheel? What does that do to horsepower?
Fidanza, nuff said. Much lighter than stock. Engine revs quicker, car accelerates quicker and the flywheel looks nicer too
Classic Moderator
Looks nicer............I see my flywheel all the time.
Whats bad about it?
Classic Mustangs are the best! Get one. |
I can't come up with anything bad......
Classic Moderator
Does it wear out faster? Do you lose torque? Could it break apart and kill me? Does it heat up if you use it hard?
No they don't wear out faster. They have a steel insert where the clutch rides. The good ones are rebuildable and have removeable weights so they fit any application. No you won't loose any torque, that is a myth. I wouldn't worry about a flywheel coming apart and killing you, its the clutch that will kill you. Any manual transmission car that is abused needs a steel safety bellhousing. Anyone that doesn't use a safety bellhousing might as well go play russian roulette. A Fidanza flywheel is SFI approved and is much stronger and more durable than a factory steel flywheel.
Classic Moderator
Sooooo, you saying that everyone with a manual transmission and I need to go faster should get one?
#8 | |
Threads Similar to: Aluminum Flywheel?
| flywheel | Blk01ponyGT | 99-04 | 5 | October 25th, 2007 11:46 PM |
| Flywheel | bbrewer03 | 96-98 | 6 | August 18th, 2007 10:47 PM |
| Aluminum flywheel and drive shaft | 02ponypackage | V6 Mustangs | 6 | April 4th, 2007 06:05 PM |
| Flywheel? | gregkelley | 5.0 Mustangs | 24 | March 17th, 2007 06:19 PM |
