Anatidaephobic
Rear end gear selection
about the car. 1966 w/ 68 302 moddified and a auto C4 tranny. my 66 has stock 2.80 8inch rear end and i am looking for performance only out of this car. 1/4 mile times is what im looking for. im tring to decide if i should go w/ the 3.80 or 4.11 locking rear end. i am leaning to the 4.11 however i don't want my top speed to be 80mph haha. also is it do-able to go from stock non-locking 2.80 to locking by just changing the center?
Big timin' in a small town
Go with the 4.11 but change that tranny out for a c6 or something with a little more gear. you can go to locking with just changing the center section as long as you get the center section with the same number of splines as the axles
Anatidaephobic
thanks i think i am going to go 4.11. but i think my c4 is the same as the c6 except the c4 is light/med duty and the c6 is heavy duty for trucks. my 302 is not putting out a ton of power but it should be above 300+hp, so i think i can still get away with the c4. i could be wrong tho.
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!! |
You should be able to get buy with the c4 but unless im wrong could you get a 3 speed auto in the later early years that I thought was a c6 mabey im wrong
Anatidaephobic
the 4.11's will give me a power conversion ratio of 10.11 and the 3.80's will be 9.3. currently i got a ratio of 6.88
ive also read that having a ratio above 9 is good so is 10 even better? or too much
It will be fine but you will lose top speed with 4.10s
#7 | |
Anatidaephobic
thanks ill be going with the 411's i just wasn't sure how much top speed i would be losing paired with my C4
check this out http://www.svtoa-atlanta.org/cgi-bin/trans.cgi
Anatidaephobic
thats pretty cool just doesn't carry the old school trans
Threads Similar to: Rear end gear selection
| GEAR OIL LEAK IN REAR END!!! HELP | chris03gt | Modular Mustangs | 5 | July 9th, 2007 04:18 AM |
| Rear gear installation | shurb125 | 5.0 Mustangs | 27 | March 14th, 2007 08:51 PM |
| Question about Rear Gear 3.73 or 4.10 ? | Xtra | 2005 - 2010 | 8 | December 31st, 2006 03:39 PM |
| Rear End Gear Swap Help | streetstang06 | General Tech | 10 | November 27th, 2006 04:46 PM |
| Rear gear size | charliemopps24 | General Tech | 4 | May 30th, 2006 07:41 PM |
