2007 Mustang GT, 66 Coupe
200ci i6 Compression Test
Hi All,
We did a compression test on our '66 inline 6 and have a few questions about the results. We got 140psi on all cylinders and no change after squirting in some SAE 30 oil so we concluded the rings were OK. I also suspect the valves and head gasket are ok since all the cylinders are the same. One thing is bugging me: The specifications for the engine state the compression should be 155-190psi at sea level. Did I only get 140psi because in Minneapolis we are about 850feet above sea level? I rechecked the procedure outlined in the shop manual. The one thing I missed was propping open the throttle plate. Could this accoiunt for the difference in compression? I turned the engine over 5 cycles on each cylinder. Thanks for any info / guidance. John
Vista Blue 2007 Mustang GT Premium Coupe 5 Speed FRPP GTA Axelbacks, AMSOIL XL 5W-20 Steeda CAI w/ High Flow Elbow, SCT xCalibrator 2
sea level and throttle plate make a diff.if you got 140 all the way i would leave it alone.
i sixing 200 six with 300 hp. |
Sounds good to me - thanks!
John
1967 Mustang Coupe 302 4V
never hurts to conduct a leak down test, though Snap On gauges are the only ones I've found to be accurate.
1966 Mustang Convertible
Sounds good to me also
. If it aint broke don't fix it. If it runs good and strong leave it alone.
Dare to Differ: STAY INLINE 1966 Mustang convertible, candyapple red, black power top, black interior, auto trans, autolite 1100 carb, Pertronix Ignitor, Scarebird 4 lug disc brake conversion, duel master cylinder. 1976 Cobra II |
Threads Similar to: 200ci i6 Compression Test
| compression 9 to 1 VS. 11 to 1 | ryanw | 5.0 Mustangs | 6 | November 13th, 2010 10:18 AM |
| White SMoke, ran compression test... | 02Gt Stang | 99-04 | 12 | September 9th, 2007 04:41 AM |
| Compression test results | 97redgt | Modular Mustangs | 3 | September 3rd, 2007 09:31 PM |
| 66 Mustang 200ci i6 - Change Breather to PCV type system | cgstarry | Classic Mustangs | 3 | September 2nd, 2007 04:00 PM |
| Compression | Clockman | 94-95 | 3 | May 4th, 2007 04:16 PM |
