Heads for a 302/Shifter change
Old September 26th, 2007, 08:51 PM   #1
keefboz's Avatar
keefboz is on a distinguished road
I was looking for something to do that would be fun and a good way to increase power, when my friend suggested getting some new heads. He said trick flow ones were really could and would substantially increase the HP and tourque.
How tough is this gonna be and is it worth 1200 bucks? I have the money, thats not a problem, but obviously something cheaper i could do to increase HP and stuff would be cool.
Also... i just ordered the hurst speed stick, i can use that on an automatic trans mission right? I'm assuming its just a change out of the actually shifter and wont affect the tranny.
Thanks in advance!
66' Mustang, Rebuilt 302, new to the game
Old September 26th, 2007, 09:30 PM   #2
Spiderz's Avatar
1965 Coupe, 351w
Spiderz is on a distinguished road
Send a message via AIM to Spiderz Send a message via MSN to Spiderz Send a message via Yahoo to Spiderz
Well I would say go for the 289 HP heads. They are closed cambered and will make higher compression. You can get them reworked for roller rockers and I'd put chevy valves in them because they are larger.... Cost me about $500 to have most of the work done, but I got the heads from a good friend who had like 8 sets just around in his garage.
If you go this way you need to make sure that you are getting the closed cambered heads tho, there were 2 sets that came out for the 289's.
Old September 26th, 2007, 10:33 PM   #3
keefboz's Avatar
when you say 289 heads, you mean the ones made for a 289 engine? I have a 302! If i sound confused, it's cos i am!
Old September 26th, 2007, 10:45 PM   #4
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
2012 Hyundai Elantra GLS
Vinyl66 has a spectacular aura aboutVinyl66 has a spectacular aura aboutVinyl66 has a spectacular aura about
Send a message via AIM to Vinyl66
yea 289 heads for a 302. my 302 has 289 hi-po heads on it. it produces higher compression.
Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!!
Old September 26th, 2007, 10:45 PM   #5
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Trick Flow heads will give you more potential in the long run than the 289 heads will. Your heads, cam, and intake are a package, and 289 heads work well with a basically stock engine, but if you ever decide to upgrade the rest, the Trick Flows will give you better gains.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old September 26th, 2007, 10:49 PM   #6
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
yea i think he was suggesting buying 289 trick flows for the 302. you could even buy 351 trick flows for the 302 not sure what combo would be better
Old September 26th, 2007, 10:53 PM   #7
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
No he was talking about factory 289 heads. It's a common swap. there aren't different Trick Flows. They're just for all small block Fords.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old September 26th, 2007, 10:55 PM   #8
Anatidaephobic
Vinyl66's Avatar
1966 Vinyl Mustang
my bad not paying attention. but yea ive done that with my car 289 on the 302
Old September 27th, 2007, 12:32 PM   #9
keefboz's Avatar
awesome, thanks for the info people..
but what about the shifter!! will that be a straight swap?
Old September 27th, 2007, 01:28 PM   #10
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
I got a t-5. I never did a shifter swap on an auto.
With you heads, make sure you change the cam, carb and headers to match.
Classic Mustangs are the best! Get one.
Old September 27th, 2007, 03:38 PM   #11
Spiderz's Avatar
1965 Coupe, 351w
Well I was pretty much talking about $600 vs $1200. IF you got the money to throw at a set of trick flow heads then go right ahead, But I was talking about having a set of old heads reworked. I feel it's a better bang for the buck. Then again I don't make $20 an hour.
Old September 27th, 2007, 07:12 PM   #12
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
cant you get a set of grt 40 heads cheap?
i sixing 200 six with 300 hp.
Old September 28th, 2007, 07:28 AM   #13
Classic Moderator
They are good heads. They are what I got, but if I have had the money I would of got some good aftermarket heads.
Old September 28th, 2007, 02:32 PM   #14
CR70fastback's Avatar
CR70fastback is on a distinguished road
Do any of you know of any good places to buy a set of the 289 HP heads that you guys were talking. Eighter in the mid west or can order from and cat or the net
You know its all about the gurth these days...
Old September 28th, 2007, 05:22 PM   #15
Classic Moderator
Which ones? I got my heads from a friend and got them reworked. I am guessing you have a 302. These heads would do your car some good.
Old October 1st, 2007, 12:52 PM   #16
Yea I think they would. I am young so I don't have all the best contacts for parts like that. Saddly all of the classic car guys around my neck of the woods are chevy guys and at least twice my age. I was wondering if there were any places on the net or any good parts catilogs where you could buy those 289 heads. I just got some scholarship money and that took nice bit of stress off of my bank account.
Old October 1st, 2007, 02:07 PM   #17
Classic Moderator
Do you have a shop around that will rework heads for you? I would go ask them if they have a set.
Old October 1st, 2007, 02:15 PM   #18
I do have a shop about 3 blocks away but I have never been there. What does a set usuially run for? I have been some places before to get a little work done here and there and some try to pull fast ones on me about the prices of parts because I am young, so I like to have a bit of backgroud info before I go in.
Old October 1st, 2007, 03:17 PM   #19
Classic Moderator
I am thinking about $500-$600 for the heads and all of the work done. Thats with the chevy vavles. You will have to get stiffer spings and roller rockers if you want them.
Old October 1st, 2007, 04:38 PM   #20
keefboz's Avatar
shifter was changed, however it didn't come with a cover!! oh well, see new thread for pics!
Threads Similar to: Heads for a 302/Shifter change
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
Heads Change 95StangSVT 5.0 Mustangs 9 March 7th, 2007 05:49 PM
Easy 400 HP from N/A SBF with Heads & Headers change! Zak 5.0 Mustangs 25 October 3rd, 2006 04:11 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
oil change BlackIce V6 Mustangs 8 July 9th, 2006 09:51 PM
