open rear end
i have an open rear end on my 68 and it really sucks. is there anyway i could make it limited slip without changing the whole rear end?
thanks |
do you have an 8 inch rear.
i sixing 200 six with 300 hp. |
460 asked a great question
but either one you can change the 3rd member only but envolves pulling the axles out to pull the 3rd member then you need to get another 3rd member with gears and a trac lok or whatever and put it in. |
if it is 8 call 800 347 1188 ext 5560 mika.ask forlock right #1810-lr.it locks on straight way and slips on turns.
i actually dont know what size the rear end is. its a 68 coupe with a 302 j code and a C4. the thing 460 was talking about, is that good for everyday driving?
thanks for all the help |
the lock right is good for every day driving or for the track.i have been running mine for three years,on and off track.
would you recommend that over a limited slip differential?
how much does it cost? is there any place i can order it online |
there are no clutches to burn out .it is about as blowproof as you can get.call the number i gave you ext5560 and ask for mica.the cost is less than three.
im pretty sure i have an 8" rear end with 28 spline axles. its a 68 coupe 302 j code with a c4, and it has the stock rear end. am i right?
thats perfect.make the call.mica will help you.tell him bill from 460 service center told you to call.
theodoor... the lockright is a good choice but maybe 460 should explain some of the noises that also come from having a racheting style locker.
with this lock right you dont have a lot of noise.it isnt built like a normal lock.you can barely hear it click on corners.
Threads Similar to: open rear end
| Open 4 Suggestions;)? | Mustang McLennan | New Members Introductions | 12 | February 21st, 2007 11:14 AM |
| Open To Suggestions | kevinhiggins007 | 2005 - 2010 | 19 | February 1st, 2007 12:21 AM |
| WTF (Trunk won't open) | gtg8920 | V6 Mustangs | 7 | January 12th, 2007 11:29 AM |
| Rear hatch wont open | Kingcater | 5.0 Mustangs | 13 | January 5th, 2007 07:18 PM |
