Discussing No fuel in the Classic Mustangs Forum. Ok fellas i need some help here... Im stumped.. I have a 1972 mustang with ...
Old October 25th, 2007, 10:47 PM   #1
No fuel
Ok fellas i need some help here... Im stumped.. I have a 1972 mustang with a 351W and It will not run anymore.. It ran ok for a while then one day just stopped. So in my hunt I found that I am not getting any fuel to the carb.. I have changed both of my fuel filters I have replaced my fuel pump and I have cleared out my fuel lines using compressed air.(thinking they my might be clogged.) I have found that i am not even getting fuel to my fuel pump so it is something before that point. Well i get a little bit but not enough to even fill the fuel filter up. What could cause this?
Old October 25th, 2007, 11:54 PM   #2
69fastback's Avatar
Maybe the eccentric(sp) fell off inside the timing chain cover. It's a little round piece that the arm on the fuel pump lays on, and as it spins it moves the arm up and down to pump the fuel.
Old October 26th, 2007, 01:01 AM   #3
1973 Coupe Mustang
pft if i know
what kind of carb. an if that did fall off in the timing cover you would be able to figure that out quick. just listen as some one tries to crank. but it sounds like the carb is clogged, maybe the jets
Old October 26th, 2007, 07:07 AM   #4
take the fuel pump off.leave the line from the tank hooked up.pump it buy hand.if you dont get fuel then,you know its befor the pump.check the rubber hose at the tank.if that is good put some gas in it.
i sixing 200 six with 300 hp.
Old October 26th, 2007, 07:09 AM   #5
when you install the pump,make sure the arm go under the accentric.
Old October 26th, 2007, 10:27 AM   #6
69fastback's Avatar
I'm thinking if he's not even getting fuel to the pump, the carb has nothing to do with it.
What kind of pump did you buy? I've seen the oreilys, and autozone pumps bad right out of the box before, so it could be that too.
Old October 27th, 2007, 07:00 AM   #7
Classic Moderator
Horseshoeing's Avatar
It could be it the fuel tank. Could be rust in the tank. I would bet thats it.
Classic Mustangs are the best! Get one.
Old October 27th, 2007, 08:50 AM   #8
I think i figured it out... i finally got fuel somehow to the carb and I noticed that fuel started spewing out of the filter by the carb. It had a leak so no pressure could be built. I also found the filter by the pump did the same thing. so i tightened them up and the battery died so ill give her a try today and see if i fixed her. thanks for all the help...
Threads Similar to: No fuel
Lucas fuel injector cleaner and fuel filter Saleen0101 Modular Mustangs 0 September 25th, 2007 03:09 PM
Fuel Pressure Regulator Leaking Fuel Buttaz V6 Mustangs 4 August 17th, 2007 11:41 AM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? 1slowhatch 5.0 Mustangs 0 April 21st, 2007 06:48 PM
Fuel Injector sizes without regulators or fuel pumps streetstang06 96-98 15 February 26th, 2006 10:02 PM
