disc brake and power steering upgrades
Old August 13th, 2006, 03:19 PM   #1
cliff is on a distinguished road
What is needed and where is the most reasonable place to get parts? I've heard of granada swaps, but is there something else that will work. What about upgrading to power steering. From what I've seen on ebay it would be too expensive. Any thoughts?
Old August 13th, 2006, 05:52 PM   #2
Fastback GT's Avatar
Fastback GT is on a distinguished road
Where are you and what do you have. I got 2 or 3 power steering setup's.
Thanks Bill
My Lug Nuts Have More Torque Than Your Honda !!
Old August 13th, 2006, 06:57 PM   #3
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
You can get a ford 9" with disc brakes too
Classic Mustangs are the best! Get one.
Old August 13th, 2006, 08:01 PM   #4
I live in oklahoma. I have manual drum setup and manual steering on a 67 coupe.
Old August 14th, 2006, 07:55 AM   #5
You can use a bracket on the 9" that lets you rear disc. I found the brackets at a swap meet and got them for $22 it's all I had left on me and he took it!
Clif,
Do you have a short or long steering shaft. Rag joint?
Thanks Bill
Old August 16th, 2006, 11:59 AM   #6
it is the short one, I believe.
Old August 16th, 2006, 12:00 PM   #7
I am not too concerned about the rear, they can stay drums.
Old August 22nd, 2006, 07:24 PM   #8
Does it matter if I have short or long? How can I know the difference? Also I have a 9 inch rear posi in my stang, so I'm told. Is ther a casting number that would tell me? I have a lot of questions since I am more familiar with chevys than fords and I plan to get answers from you one way or another.
Old August 22nd, 2006, 08:51 PM   #9
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
There might be an ID tag on the rear but if it has been swapped in it probably wont do you any good. the easiest way to tell if its a 9" is to look and see whether or not it has an inspection plate. If it has an inspection plate, its not a 9". If the only way to get the gears out are by taking the third member out from the front its a 9".
Here is a link to an identification page you may find helpfull.
Old August 26th, 2006, 01:54 PM   #10
I would like to know if anyone has done a conversion and how to do it. drum to disc and manual steering to power steering.
Old September 9th, 2006, 09:02 AM   #11
Fastback gt how much would you take for one of those p/s setups?
Old September 9th, 2006, 12:51 PM   #12
raceruler03's Avatar
2000 mustang gt
raceruler03 is on a distinguished road
Send a message via AIM to raceruler03
Yeah I'll second the notion how much will it cost me to make the front brakes on my 69 disc?
Old September 9th, 2006, 01:27 PM   #13
66gtmustang is on a distinguished road
probably a little over $1300 or around 1300 also depends if you want a power booster and you can check out stainless steel brake corp ive heard good things about them. They have brake kits for like everything. Here's the URL
http://www.stainlesssteelbrakes.com/
Threads Similar to: disc brake and power steering upgrades
Disc Brake Conversion wonders_of_a_V8 Classic Mustangs 6 January 20th, 2009 09:16 AM
Brake Upgrades/ SN95 Spindles and Cobra Big Brake Kits OcOnnor220 Modular Mustangs 2 July 8th, 2007 12:36 AM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
Got another disc brake problem. lucidsoul5 General Tech 0 July 24th, 2006 10:46 PM
