Discussing 5.0 in 1967 Coupe? in the Classic Mustangs Forum. Hi all Just wondering how hard it is to put a 1989 5.0 HO ...
Old November 14th, 2007, 01:05 AM   #1
5.0 in 1967 Coupe?
Hi all
Just wondering how hard it is to put a 1989 5.0 HO engine in a 67 coupe originally 289? Will it just bolt straight in? Can I throw away the efi and fit an Edelbrock intake and carb or similar? Will my C4 bolt straight up? Any hassles with mounts for original 289 power steering pump / accessorys etc? Also I want to lower the car 1 inch, with 17" rims whats the recomended offset/back space and tire size front/rear. Alot of questions but any info appreciated.
Thanks.
Old November 14th, 2007, 07:25 AM   #2
Classic Moderator
Horseshoeing's Avatar
The 5.0 is easy to put in. It is easier to put a carb on then mess with the EFI, but you can get more horses with a EFI. I am not sure about all of the accessorys. Lowering the Mustang is easy, but the 17" rims are pushing it. I don't know the offsets you need.
Classic Mustangs are the best! Get one.
Old November 14th, 2007, 08:21 AM   #3
leave the 17s alone.
i sixing 200 six with 300 hp.
Old November 16th, 2007, 06:25 PM   #4
It will bolt up, but don't throw away the EFI! Sent it to me!
Some of the later 5.0's had reversed the water pump inlet. I can't remember what year that started but I think the 89 is the same as the 289. Anyway you could just change the pump, the old style will bolt up.
Not sure about the brackets for power steering ect., but the worst case scenario you can swap the timing cover, water pump and basically use the whole front of the old motor. probably won't need to do that though.
The 89 might have a rear sump oil pan, won't work on your car.
Old November 16th, 2007, 08:51 PM   #5
1965 Mustang Fastback
c4 will bolt
302 will fit easily
17 will fit also i thought thats what they all were
Old November 16th, 2007, 10:16 PM   #6
8t6gt's Avatar
1986 Mustang GT
Originally Posted by nba1341 View Post
c4 will bolt
302 will fit easily
You thought they all were what 17 in are you serious
Hurst Crew member #2 of 21
Co Founder of all crews.
Lee B and 8t6 the founders of crews
Originally Posted by Squints View Post
i'm all for global warming. who needs polar bears anyway?
Old November 16th, 2007, 10:23 PM   #7
isnt this 17
Old November 16th, 2007, 11:27 PM   #8
8t6gt's Avatar
1986 Mustang GT
Yeah those are but I thought you meant all mustangs came 17
Old November 16th, 2007, 11:31 PM   #9
oh you guys are saying like its impossible i thought mine where and then i read this posts like 17s no no no
Old November 16th, 2007, 11:37 PM   #10
8t6gt's Avatar
1986 Mustang GT
Yeah yours are chill chill.
Old November 17th, 2007, 12:58 PM   #11
I pulled this identical swap off on my 72 Maverick, although I retained the EFI system. If you're going to go to this much effort, enjoy the fruits of EFI! I ran the original C4 trans, but you will have to balance match the original C4 flexplate, as the later EFI 302s runa 50 oz. imbalance, The earlier 289s & 302s ran a 28 oz. inbalance. Additionally, if you run the EFI, the kick down cable will have to be fabricated. The only other issue would be the return line to the fuel tank. Ron Morris Performance has a sender to accomodate the return line. In fact Rom Morris has all the goodies to pull this entire swap off from the EFI harnesses to the fuel lines. A very knowlegeable guy who will answer any of your questions if you run into any snags. It's pretty straight up swap, if you have the harness and the ECU. You can check out my Maverick in the January '06 issue of Mustang & Fords. Ron Morris's contact info is: ron morris performance or 209-605-1590. Hope this helps.
The difference between a girlfriend and wife is about 50 pounds.
Old November 17th, 2007, 03:15 PM   #12
Oh, one other consideration...If you are going to carburate a 5.0 EFI motor, there are inherent problems with driveability and idle quality. The reason is because they are roller motors and the cam profiles were not designed for carburetion. Though this can be overcome by selecting a different cam profile.
Old November 18th, 2007, 08:33 AM   #13
Classic Moderator
So your saying he will need a new cam?
Old November 18th, 2007, 11:19 AM   #14
The current cam will work, but he will have driveability issues. So yes, he should replace the cam for optimum performance and driveability.
Threads Similar to: 5.0 in 1967 Coupe?
1967 Mustang - Please Look mustangkid Classic Mustangs 13 November 14th, 2007 08:24 AM
1967 5 lug WeCircleTheProblem Classic Mustangs 5 August 24th, 2007 07:04 AM
help on getting the right 1967-69 Mustang cleary Classic Mustangs 9 February 17th, 2007 06:42 PM
1967 coupe how much, 289 engine cleary Classic Mustangs 10 February 14th, 2007 11:39 AM
1967 Fastback Headliner cliff For Sale 3 November 18th, 2006 12:02 PM
