Anatidaephobic
Suspension Packages?
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!! |
stage 3 looks right good.
i sixing 200 six with 300 hp. |
Look Ma! My First Post!
1965 mustang coupe
never ran it
Not sure how much you are willing to spend on your suspension but i must say the RRS setup on my mustang is awesome! Koni Shocks, Eaibach springs, (coil over/strut suspension) handles great and looks damn sexy with the brembo brakes. Check it out at rrs-online.com i currently have the phase 5 setup and im lovin it. Only issue is you have to use 18 wheels for the phase five setup, but they have all regular components of the same setup for alot cheaper for smaller wheels and not racing components.
Depends on what you want to do. Global West is a good company.
Anatidaephobic
right now i am just looking around. in the future i want to upgrade the suspension b/c right now at speed going over a bump is kinda like diving into a water bed. it just feels like the car sloshes around.
Anatidaephobic
is there anyway i can keep my rear end from squatting onto my rear tires without raising the ride height?
1965 Coupe
is the problem the tires hitting the quarter panel, or inside the wheel well?
Classic Moderator
Some KYB shocks would help your stang.
Classic Mustangs are the best! Get one. |
Anatidaephobic
quarter panel. they stick out just a hair too much toward the upper back part of the wheel. they wheels barely touch however its already wore some paint away.
Classic Moderator
what size tire do you have? Is your offset right?
Global West has top quality stuff. I bought their reverse eye rear leaf spring setup and it is top shelf. Doug is a very knowledgeable guy as well.
2004 Mustang GT The difference between a girlfriend and wife is about 50 pounds. |
1965 Coupe
I hate to suggest it, but worst comes worst, and you can flare the wheel wells out a little, that'll stop that, and if it's done right it'll look pretty kewl
Are the leaf springs original? If so they probably need to be replaced.
Anatidaephobic
more than likely yes. i want to basically replace the whole suspension for the car. however if i do i just want to be sure that im still not going to rub. i love the way the car looks right now so i don't want to do a flare or adjust ride height, just restrict how far the rear end will squat over bumps and on launches.
#15 | |
#16 | |
Anatidaephobic
would the same spring replacement help me out with my rubbing on my 70. A couple times it really garbled up my tires
![]() You know its all about the gurth these days... |
1965 Mustang Fastback
my tires get all cut up too
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
1969 Mustang Mach 1
6.824@101.61
What size tires do you have? I'm not sure about the 65, but with the right offset, you can run some pretty wide tires in the 69-70 with no issues.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
The wheel well housings are quite a bit larger on the 69/70s then the 65/66s.
Certainly wheel offset (backspacing) is the key to fitting larger tires under your steed.
Threads Similar to: Suspension Packages?
| CAI and tuner packages | hitman38mod | 2005 - 2010 | 24 | October 8th, 2007 11:31 PM |
| Top end packages | troy1000rr | General Tech | 1 | April 28th, 2007 11:33 PM |
| Wheel & Tire Packages? | silver2005gt | 2005 - 2010 | 10 | April 11th, 2007 07:47 AM |
| power packages | kratos2250 | 5.0 Mustangs | 5 | February 28th, 2007 09:07 PM |
| 05/06 gt Ronalee packages | 99mustang232 | The Clubhouse | 3 | February 19th, 2006 03:51 PM |
