Discussing Edlebrock or Holley in the Classic Mustangs Forum. Originally Posted by 460brevill cprstreemachines when running a radical cam the manifold vaccume drops,this ...
Old January 10th, 2008, 12:42 PM   #41
cprstreetmachines's Avatar
Originally Posted by 460brevill View Post
cprstreemachines when running a radical cam the manifold vaccume drops,this lets the needle lift off the seat.this causes a rich condition at idle.all you have to do is put weaker springs in to let needls reset, on a holley you have to tear down and rejet.
Oh I know. But that is a pretty radical cam. But as the carb was designed, that is not how they are used. Holley is the same way. If it is open at idle, you tear it down and put in a smaller PV, you don't ever change the jetting for idle. They are only for cruise and WOT.
Classic Performance Repair
www.CPRstreetmachines.com
Old January 10th, 2008, 03:14 PM   #42
1966 Mustero
12.50
Holly Street Avenger series,Best out of the box bolt on carb holly has sold for the street!
depending on horse power a 670 series avenger should be just about right.
Old January 10th, 2008, 03:50 PM   #43
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Thats what I have and I like it, but when I pull the engine in a few months, it's getting a street demon.
Old January 10th, 2008, 04:55 PM   #44
Just curious on the switch if you like the holley ?
Old January 10th, 2008, 06:07 PM   #45
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
I have had them all, and I like the street avenger, but I realy like the performance, and driveability aspects I've had when running Demons. They cost a little more, but I think you get what you pay for.
Old January 11th, 2008, 11:32 AM   #46
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Oh, and I forgot that the street avenger sits just a little bit higher than a standard holley, and I'm having hood clearance problems. My air cleaner has dents in it from hitting the studs that hold the scoop on when the engine torques. I think the stress that puts on it is what's causing my intake to leak.
I have the drop down bottom piece on the cleaner. I'm going to try to find a smaller diameter cleaner that still drops down to try and solve the problem.
Old January 11th, 2008, 12:41 PM   #47
They sit higher ? Did not know that. There are a few tricks you can do at home. How much more room do you need. Doesn't sound like much. Do you already have the 1.5 drop base or just the 1in ? You can trim a little metal from the base of the cleaner where it meets the carb. You can take the down pretty far, until it hits the needle and seat adjustments. The K&N top will give you a little more room also. they flex more than your standard top when you tighten them also.(If you take the metal mesh out from underneath.)
Old January 11th, 2008, 12:51 PM   #48
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Yeah I have 1.5 drop, and I've never had this problem with other Holley carbs. I can't say it sits higher I guess until I actually check that out...lol, but this seems to be the only carb that's given me trouble.
Threads Similar to: Edlebrock or Holley
bbk holley and edelbrock cali 5.0 5.0 Mustangs 19 October 21st, 2007 12:39 AM
holley carb 9teen65coupe Classic Mustangs 10 August 22nd, 2007 08:15 AM
holley intake cali 5.0 5.0 Mustangs 8 April 21st, 2007 12:54 AM
almost new EDLEBROCK 65mm T/B vfast For Sale 1 January 28th, 2007 09:33 PM
New Holley Red Pump On!! GTXRacing General Tech 7 April 28th, 2006 02:56 AM
