Need Help... Cant Figure Out
Old September 6th, 2006, 02:00 PM   #1
mustangrebuilder will become famous soon enough
ok i have taking the rear of my 68 mustang a part and putting new axles and disc breaks.....but i dont get is how you get the axles out of the housing i have taken off all the bolts that are on the end holding the drum breaks on but it still will not come off.........
Old September 6th, 2006, 04:13 PM   #2
Fastback GT's Avatar
Fastback GT is on a distinguished road
They don't come out easy to often. one of my tricks is I bolt the drum on backwards and hit it out with a dead blow hammer.
Thanks Bill
My Lug Nuts Have More Torque Than Your Honda !!
Old September 6th, 2006, 07:05 PM   #3
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
Did the 68s have c clips or were the axles held in by the backing plate? Either way, If it were c clips make sure they are out if its backing plates, make sure the entire brake backing plate is off. If all this is out, try turning the drum around as Fastback GT suggested or you can go down to your local Autozone and rent a slide hammer and attachment. That will surely do the trick.
Old September 6th, 2006, 10:00 PM   #4
Switching to disc I assume the breaks are off. but there are on c clips and the backing plates don't have to be off. The slide hammer would help.
Thanks Bill
Old September 6th, 2006, 11:28 PM   #5
see there is no backing cover on the axle housing it is welded on...or are u talking about the backing plate of the breaks????????
Old September 7th, 2006, 12:48 AM   #6
The backing plates. The back of the houseing should be welded its not a chevy. as long as the 4 nuts are off the in side of the backing plats they will come out. you have to turn the hub and line up the hole in the hub with the 4 nuts and remove them one at a time and the axles wii come out.
Thanks Bill
Threads Similar to: Need Help... Cant Figure Out
cant figure it out notsoslow50 5.0 Mustangs 7 July 12th, 2007 10:25 PM
go figure! P.O.S-GT 5.0 Mustangs 3 June 22nd, 2007 11:13 AM
Figure this out... Foxstang90 5.0 Mustangs 3 February 18th, 2007 01:15 AM
Trying to figure out this problem Plays With Squirrels 96-98 4 January 10th, 2007 12:07 AM
cant figure it out ttop5.0 5.0 Mustangs 2 August 26th, 2006 07:54 PM
