Discussing Best way to take care of a small rust spot in middle of the quarter panel in the Classic Mustangs Forum. The spot is less then the size of a dime, however at eye level it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1969 2 door coupe grande
Best way to take care of a small rust spot in middle of the quarter panelMy intents are to lightly sand the spot then tape off the whole car and spray this spot with that primer. What are some recomendations about doing the paint? In this picture you can see the spot right above the rear wheel, right smack in the middle of the quarter.
Check out my 351 4 barrel swap in my 69 coupe here http://www.moddedmustangs.com/forums...-351-swap.html ![]() Yes, I am the moon master
It's hard to tell from the photo how minor it is, if its really minor I'd use 400 or finer sandpaper and just get rid of all the rust and repaint. If it's beyond that you can really only sandblast (which doesn't seem to be worth it for the tiny spot) or chemically treat it... which seems to be what you want to do.
I don't personally know anyone whose used rust removal stuff that turns it into primer. I'd probably go for something that just gets rid of the rust, then touch it up. Talk to your mechanic, see if he knows anyone whose tried it/had good results.
Let me go get a good shot of it
I couldn't really get that great of shot, the camera wouldn't focus.
1969 Mustang Mach 1
OLDNSLO
Just cover it with body filler and call it good
![]() no really don't do that. I personally wouldn't use that spray. regardless of what it claims, you can't cover up rust and the only way to get rid of it, is to do just that...get rid of it. If it's truly surface rust, you can sand it down and spray some paint on it, but chances are, it'll come back. Eventually, it will have to be cut out. That's just the nature of the beast when you own a classic. My car is starting to have rust bubbles pop out in the normal Mustang places. That's why they are a full time job.
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
Yea, theres a spot on the bottom of the passenger side door that doesn't make it's self as obvious. I'm going to attempt sanding that down a bit and doing a touch up just for this show season. I have quite a few connections with painters and body shops though 4 off the top of my head. Got a good deal with the one guy on getting my riceburner painted.
I'm still trying to figure out why the vent or whatever you wanna call it on the side on the rear quarter is mounted like it is. I think if they had mounted it 180 degrees the other way it would have looked better.
#6 | |
1965 Mustang Fastback
how does rust form?
1986 Mustang GT
Its called oxidation NBA. Water and air mix on bare metal to form something called Rust it eats away with corrosion. Then once its there its like Herpies you cant get rid of it
1965 Coupe
unless you use sandpaper and a wirebrush? That would hurt.
1966 Vinyl Mustang
get yourself some chewing gum and white nail polish. 2 mins are your done!
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in the Garage |
#11 | |
1966 Vinyl Mustang
well.....welcome to it right? At least I dont have this problem with the focus yet.
Threads Similar to: Best way to take care of a small rust spot in middle of the quarter panel
| Rear quarter panel question | energiesource | 99-04 | 20 | August 29th, 2007 01:29 AM |
| Parting out '99 Cobra.. wrecked in the quarter panel.. | brent_cosenza | For Sale | 28 | July 19th, 2007 05:17 PM |
| Rear Quarter Panel Replacement | punxrus | 96-98 | 2 | February 13th, 2007 11:46 PM |
| quarter window panel | charlesnash | 2005+ | 3 | December 24th, 2006 06:57 PM |
| 2001 Mustang Quarter Panel | Aeriform | V6 Mustangs | 12 | November 8th, 2006 01:43 AM |
