Transmission Leak
Old January 12th, 2008, 11:27 PM   #1
1973 Coupe Mustang
as fast as the restoration is going
Katen will become famous soon enough
Send a message via Yahoo to Katen
Transmission Leak
K so i rebuilt my c4 last year round this time. Any who i found out that it is leaking again. so i think it is on the transmission pan which leads me to think that the guy i got it off originaly gouged the mating surface on tranmisssion where the pan bolts to. sorry to sound stupid or patrinize others but just want to get the idea accrossed where it is at. now can i just get that milled down or do i say screw it an buy a 1200 tranmission from jegs or summit? Please give your thoughts an ideas thanks
Keith
Old January 12th, 2008, 11:38 PM   #2
BigBlockFairlane's Avatar
BigBlockFairlane is on a distinguished road
Honestly it would have to be pretty smashed in not to seal.
I'd fill any grooves with JB weld.
More likely the pan screw holes are puckered and need to be peened flat or its not leaking at the pan but at the input shaft bushing. The pump seal is important but that bushing is what takes full pressure. On a rebuild that needs to be replaced. I have 2 cars that leak like freakin crazy now that need it done.
http://i95.photobucket.com/albums/l148/supercobrajet/Boostednotch.jpg
Old January 12th, 2008, 11:44 PM   #3
1973 Coupe Mustang
See i replaced all of that when i rebuilt it. an i did flaten out the tranmission pan. but instead of a cork gasket i used rtv do you think that might be it
Old January 13th, 2008, 09:29 AM   #4
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Use 2 gaskets.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old January 13th, 2008, 03:29 PM   #5
1973 Coupe Mustang
you dont duble gasket anything bro. that will actualy make it leak more so. plus i think i am just going to get a new transmission so it can hold more ponnys.
Old January 14th, 2008, 08:40 AM   #6
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
get a good b@m and foget it.
i sixing 200 six with 300 hp.
Old January 14th, 2008, 01:46 PM   #7
1966 Mustero
12.50
Mustero is on a distinguished road
Reseal the pan with a single cork or even a silicon or composit gasket & some good rtv,but also check your dipstick/filler tube & make sure it is not the problem.I usually like to use rtv along with the o-ring to make sure theres no leaks there.
Old January 14th, 2008, 02:01 PM   #8
1965 Mustang Fastback
nba1341 will become famous soon enough
took us 5 tries to seal the rebuilt c4 in my car and 2 diffferent pans + a trans cooler
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old January 15th, 2008, 08:03 AM   #9
460brevill's Avatar
if you use your trans,get an aluminun pan from jegs.it will seal better.
Old January 15th, 2008, 02:19 PM   #10
+1 finally got a trick flow aluminum pan
I'm a good boy now.
Old January 16th, 2008, 01:05 AM   #11
1973 Coupe Mustang
well the rtv didnt work the cork gaskets didnt work when i used them to. so i think i will try the tranny pan from jegs. if that does not work i will get a new transmission
Old January 16th, 2008, 07:11 PM   #12
460brevill's Avatar
trans leak
i did a c4 leak today.it was the accumalater cover making it look like the pan was leaking.
Old January 17th, 2008, 05:09 PM   #13
7DMACH1's Avatar
1970 Mach1
11.42
7DMACH1 is on a distinguished road
More than likely it's not the pan leaking. The lever seals are famous for leaking. This is the seals on the levers right above the pan. They leak and it looks like the pan is leaking. Just my .02
Old January 17th, 2008, 06:17 PM   #14
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
Friggin flyboys, never double gasket anything, the fluids just squirt out between them. pull the pan clean every bit of fluid / oil off of the mating services. Put on the new gasket with RTV and lightly tighten, let set 24 hours and torque as specified.
Old January 19th, 2008, 10:47 AM   #15
460brevill's Avatar
they have a dye you can put in your trans and ride around the block.check it with a black light and you can see where it is comeing from.
Old January 29th, 2008, 12:50 PM   #16
Look Ma! My First Post!
68mustang is on a distinguished road
torque specs
do you know what the torque specification is fot an '68 c4 automatic
Threads Similar to: Transmission Leak
Transmission Leak? 05MUSTANG4.0 V6 Mustangs 6 September 3rd, 2007 06:10 PM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
transmission leak 69fastback Classic Mustangs 2 February 21st, 2007 10:39 PM
Oil Leak Stangzilla 5.0 Mustangs 25 November 6th, 2006 05:00 PM
transmission fluid leak 87vert 5.0 Mustangs 6 January 8th, 2006 11:41 PM
