Car not shutting off HELP!!!!
I have a 67 mustang with an I6 200 under the hood. I just put a new solenoid all the wiring is ok and I can get the car to start but I can't get it to shut down. Help!!!
1969 Mustang Mach 1
6.824@101.61
Sounds like a grounding problem.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1965 Mustang Fastback
installed solenoid wrong?
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
if the engine starts and want shut off your problem may be the ign. switch.if the starter want stop spinning you may have wired wrong,or the starter is stuck.
i sixing 200 six with 300 hp. |
1967 Mustange Coupe, 200i
I've had a similar problem. I could completely disconnect the ignition switch and the car would remain running. Try smacking the starter solenoid with a screw driver when it stays on after removing the key. That would at least eliminate a sticky solenoid. Also, make sure ALL of your starter electrical connections are clean, especially ground.
If it is an emergency, just unplug the coil.... but maybe put the old coil back in to see if you still have the same problem, if no then you have a bad solenoid.
Was the replacement solenoid made in China? hahaha
Threads Similar to: Car not shutting off HELP!!!!
| why does my car act like its shutting down at 125mph | brianstang | 96-98 | 29 | August 13th, 2007 09:33 PM |
