Discussing Tech Question-T/5 Install 65 in the Classic Mustangs Forum. Hello Gang, Question for you. Installing t-5 in 65, I am using a 351 ...
Old January 25th, 2008, 06:02 PM   #1
Installing t-5 in 65, I am using a 351 roller block that has no boss
for clutch..So I bouth a Modern Drive -www.moderndriveline.com
clutch cable kit and a pony car adapter plate.
Now here is where it gets good..per the install
instructions I should thread the clutch cable through bellhousing mounting hole There is no hole on a 65 bellhousing it also pushes and this kit
pulls? So do I get another housing that pulls? the drawings show a 65 ?
Have I been in the garage to long?
Thanks in advance
Old January 25th, 2008, 11:26 PM   #2
Early 65s could have come with a 5 bolt bellhousing. The 4 bolt style was a mid year change. The 5 bolt bellhousing is somewhat rare so don't pitch it, but it sounds like you will have to switch out the bellhousing to the late 4 bolt style. Hope this helps.
The difference between a girlfriend and wife is about 50 pounds.
Old January 26th, 2008, 06:46 AM   #3
i used a late 6 bolt bell and it worked perfect.
i sixing 200 six with 300 hp.
Old January 26th, 2008, 10:51 AM   #4
You are correct, My bad, I should have said 6 bolt, not 4 bolt.
Old January 26th, 2008, 04:02 PM   #5
Thanks guys, Im going to return the cable and put a bracket on the
bellhousing to use the OEM rod..
Old February 5th, 2008, 06:12 PM   #6
1966 Mustero
12.50
You could also just use the stock t-5 bell housing.Then the cable system will work.I've installed t-5's in 66-69 with 298's 351W's and 351C's. It's no big deal
www.bigdmustangs.com
Truth is Truth whether YOU believe it or not
Old April 11th, 2008, 02:35 PM   #7
Look Ma! My First Post!
Mustero,
Could you please email me, I would like to have your email address so I can ask questions, I'm currently working on putting a 351W with a T5 in my 66 and would like to know a few things.
Email address: cruickshankb@yahoo.com
Threads Similar to: Tech Question-T/5 Install 65
look wut came in the mail! small tech Question blown96stang V6 Mustangs 17 October 22nd, 2007 04:08 PM
Tech question here. ujslost Modular Mustangs 8 September 14th, 2007 12:41 AM
Pics from the car cruise and a tech question :wink neckbonekat 99-04 5 June 8th, 2007 01:49 PM
V6 Cam install question 02ponypackage V6 Mustangs 6 February 14th, 2007 01:20 PM
Tech Gear Question 3.8Coastie V6 Mustangs 3 August 26th, 2006 10:02 AM
