Fill The Gas Tank
Old September 25th, 2006, 12:06 AM   #1
theodoor24 is on a distinguished road
Fill The Gas Tank
i just recently purchased my first mustang its a 68 coupe with a 302 v8
and the first time i went to fill it up with gas i had some problems. i knew that the pump would not stay in the tube because the person i bought it from told me, but first of all the gas seemed to keep back flushing and spilling out onto the ground and then the pump kept popping off. could anyone please help me with this, any tips. just for the note the gas cap is in the back just under the trunk
Old September 25th, 2006, 01:57 PM   #2
mustangrebuilder will become famous soon enough
there could be sumthing in the line....that happened to my friends 67 mustang...just check the lines for stuff in them cause your saying its backing up right???
Old September 25th, 2006, 02:45 PM   #3
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Could your gas hose in trunk have a kink in it?
Classic Mustangs are the best! Get one.
Old September 26th, 2006, 12:17 PM   #4
no there was no kinks or opstructions in the line. but that was the first pump i tried, i tried a different gas sataion yesterday and that worked fine. but thanks for the tips
Old January 22nd, 2007, 10:04 PM   #5
2000 Honda C/1968 Mustang
68pony is on a distinguished road
Send a message via AIM to 68pony
Re: Fill The Gas Tank
Different stations have different pumps. I have found about 3 stations around my house that I can easly use.
Originally Posted by Horseshoeing
In a 1965 Mustang the traction control is the gas pedel.
I need to drive my Mustang more......
Old January 22nd, 2007, 10:47 PM   #6
Steamboat 16 is on a distinguished road
i don't know on your car but sometimes there is a bend in the pipe that is suposed to be there and when the gas goes in it doesn't flow through fast enough. this is true for my dads old jeep. EX: the kind of pipe structure i'm talking about is like the one directly underneath any sink in your house.
Sex, Eating, and Driving Fast, the Three Greats in life and I can do all of them without leaving my MGM
Old January 24th, 2007, 09:08 PM   #7
dark70's Avatar
dark70 is on a distinguished road
Ya, I've owned two 67 coupes and they both had that problem. I would back off the pump pressure so the fuel doesn't flow as fast. There's usually several notches in the fuel pump handles for different flow rates.
Old February 24th, 2007, 02:44 PM   #8
latamud is on a distinguished road
Add a vent somewhere on your filler tube. It will keep escaping air to push your fuel back out the filler neck.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS
66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project)
03 Viper, Supercharged
Old February 24th, 2007, 05:04 PM   #9
dark70's Avatar
I'd be careful about opening a whole between the gas tank and the trunk. Your trunk could fill with fumes from all the tank sloshing and if there's a spark for whatever reason...
Old February 24th, 2007, 05:34 PM   #10
don't just poke a hole in it. run a vent tube routed out of the trunk.
Old February 25th, 2007, 11:25 PM   #11
This is the best solution. I have to do this and all the classics around me do this. It cost nothing and isn't hard to do.
Threads Similar to: Fill The Gas Tank
Pulling stock shifter to fill with tranny fluid. Need tips Saleen0101 Modular Mustangs 4 April 11th, 2009 07:10 PM
HOW TO FILL UP TORQUE CONVERTER? oasr87 V6 Mustangs 3 July 10th, 2007 04:58 PM
fill spolier holes juan310 Visual 4 April 20th, 2007 09:38 AM
What a Tank!!! Stangzilla Videos 3 March 2nd, 2007 12:07 PM
Makes me fill bad FOR POINT SIX 99-04 20 December 15th, 2006 03:47 AM
