Discussing 400hp 289? in the Classic Mustangs Forum. they can be too big ask darrell on that one...
Old February 26th, 2008, 07:20 PM   #21
1965 Mustang Fastback
they can be too big
Old February 27th, 2008, 08:47 AM   #22
i put a set of 1969 351 w 4 barrel heads on my 289 and it made a world of power.
i sixing 200 six with 300 hp.
Old February 27th, 2008, 10:19 AM   #23
Vinyl66's Avatar
1966 Mustang
what kind of carb did you have on that?
Classics or Have a Nice Day!
Pittsburgh Steelers/Penguins/Pirates FTMFW!!
1966 Ford Mustang w/ Black Vinyl top
Mods listed in the Garage
Old February 27th, 2008, 03:37 PM   #24
750 holley.
Old February 27th, 2008, 06:17 PM   #25
Vinyl66's Avatar
1966 Mustang
anyone ever try patriot sbf heads?
with those and comp cams xtreme energy 284H cam kit, rpm air gap intake, and a holly 4150 750cfm carb would be just over 2k. any good for 2k?
Old February 27th, 2008, 06:19 PM   #26
your installing this yourself correct?
Old February 27th, 2008, 06:22 PM   #27
Vinyl66's Avatar
1966 Mustang
yea ive put together and tore apart several engines. just never built my own by selecting parts and shit
Old February 27th, 2008, 09:53 PM   #28
Vinyl66's Avatar
1966 Mustang
hmmm forgot the rockers and rods so closer to 2500
Old February 27th, 2008, 09:55 PM   #29
MM Site Moderator
GTsetGO's Avatar
12.88 @ 112
emailed my boy, says he is going to try and talk to the shop to figure exactly what they did
www.myspace.com/gtsetgo
www.myspace.com/philfriedman
www.myspace.com/echo4rocks
originally posted by Racerchik02:
While you're down there........
I win...while screaming GETSETGOGOGOGOGOGOGOGOGO
Old February 27th, 2008, 11:01 PM   #30
69fastback's Avatar
Save your money on the Patriot heads. I haven't heard a single good thing about them.
Old February 27th, 2008, 11:07 PM   #31
Vinyl66's Avatar
1966 Mustang
heard anything bad then?
Old February 28th, 2008, 08:54 AM   #32
69fastback's Avatar
Yeah, I've heard you're not going to see much power gain becuase they have a poor runner and port design. I've also heard they're fragile if you ever get them hot, or have any other problems. There's a reason they're cheap.
I'm sure they would have to better than stock though
Old February 28th, 2008, 09:02 AM   #33
overheat one time and beware.i would rather have a set of gt40 and put big valves in them.
Old February 28th, 2008, 12:53 PM   #34
Vinyl66's Avatar
1966 Mustang
are all the gt40 heads the same? b/c i know a guy that has a iron set out of a 90's bronco
Old March 5th, 2008, 05:51 PM   #35
Just finished my 289. I used a set of ProComp alum heads with 190cc runners and 2.02/1.60 valves and it runs great. They ran about 1000 for the set. They arent "AFR's" but great value for the money and have given me no problems. The imports hate me haha. But then again, I have no concerns about overheating due to a custom radiator that only ran me about 300 bucks. Making about 350 horse on NA cam. Alot of fun!
1964 Falcon Sprint 4 speed
1965 347 Cyclone 4 speed, B/FX clone
1993 Mustang Cobra (red/grey cloth)
Old March 5th, 2008, 06:08 PM   #36
Vinyl66's Avatar
1966 Mustang
so you like the procomp heads? ive heard some bad stories about their castings
Old March 9th, 2008, 02:32 PM   #37
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
Head a Good Build:
All you need for real power is more fuel and air per Bang.
331 Stroker kit for 30 over 289 $849 fordstroker.com
Cam : SUM-k3606 234/244 .520/.544 rpm 3400/6800 $89.95 needs stall on C4's
Carb: HLY-0-80670 670cfm $369
Intake: Air Gap EDL-7521 $239
Heads Procomp 190 cc $759
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old March 9th, 2008, 02:45 PM   #38
MustangOne's Avatar
12.6 @ 114.3
That build will will get to the 400 hp number for $2305.95
and also you can spray this motor. Just remember the more power you make the easier it is the find your weak links in your drive train. with 190 cc heads you need to go with a flat top piston to get 10.5 compression. with set up I would use a 3:55 gear for you rearend. and fit a 27" tall tire or bigger under your 1966 stang. Good Luck
www.Mustang1.Com
Old March 9th, 2008, 02:55 PM   #39
1965 Coupe
he's already said he wants to keep stock displacement though, he's trying to make 400 with 289 cubic inches, not 331
http://i17.photobucket.com/albums/b57/mustangclint/SIG-Zers.jpg
Old March 9th, 2008, 02:56 PM   #40
MustangOne's Avatar
12.6 @ 114.3
Then what is the point. I would like to Get 32 mpg out of my Superstang.
www.Mustang1.Com
Threads Similar to: 400hp 289?
---Have 5 grand want 400hp--- WTFJayJay 5.0 Mustangs 117 August 27th, 2007 05:12 PM
new m3 v8 powered...400hp+ jat 2005+ 7 April 21st, 2007 11:11 AM
