Discussing 400hp 289? in the Classic Mustangs Forum. same thing i said mustangone.looking for a lot from a little.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 |
i sixing 200 six with 300 hp. |
#42 |
1979 mustang 5.0
hopefully 11's when complete
you can make a 289 hit 400hp easily my friend, but it won't be a street machine..... RPM's are key!!! Someday I want to spend a ton of money on a 289, my plan would be this.
Dart block, trick flow heads, weber carbs and obv the best crank, rods and pistons money can buy..... Get that puppy to turn at 10,000+rpm's with 12.5:1 compression!!! That's how you get a 289 to make more than 400hp my friend.....
1979 hatchback: -351w w/ 10.5:1 -Tremec TKO |
#43 |
1966 Vinyl Mustang
if i end up stroking it ill just use my 302. its already bored.030.
and have you used the procomps before? ive been told to stay away from them by a few locals
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in the Garage McCain/Palin 08 Last edited by Vinyl66 : March 11th, 2008 at 11:17 PM. |
#44 |
yes,you can hit 400hp,but he only wants to spend 3000.00.a lot for a little.
#45 | |
1969 Mustang Mach 1
OLDNSLO
You won't have one that will last very many miles if you're twisting 10,000 RPMs. As I said previously, horsepower doesn't blow up engines, RPMs do.
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
#46 |
1968 GT 500 Super Snake
12.6 @ 114.3
If you stroke your 302 with the build that I posted, the 331 be a Great Motor that will last. and can make 400hp and live. Good Luck,if you like to see some of my motors go to my site and watch the video's. I am not new to this quest of yours.
#47 | |
1979 mustang 5.0
BTW this would be a moonshine running car, no traffic to worry about at 2am and it's not like I'd be stopping right??? hahaha just kidding, well maybe I might need a side job if gas hit $4 a gallon!!!!! ![]() ![]()
#48 | |
1969 Mustang Mach 1
OLDNSLO
The 289 is a great engine, and it's capable of turning some RPMs, but be sure to put a solid cam and lifters in it. There's nothing like the sound of a solid cammed engine wrapping up
#49 |
12.6 @ 114.3
The 1964 / 1965 Daytona coupe was a 390 hp@6750 rpm
The Shelby Cobra Daytona Coupe Specifications 1964 & 65Total Built 6EngineTypeV-8,iron block, water cooledHeadCast iron, removableValvesOverhead, pushrod/rocker-actuatedMax BHP390 @ 6,750 rpmMax Torque341 lbs-ft @ 4,000 rpmBore4.05" (101.6mm)Stroke2.87" (72.9MM)Displacement289cid, 4736ccCompression Ratio10.8:1Induction system4 Weber 48 IDAExhaust systemStandard, dual exhaustElectrical system12-volt distributor systemChassisFrameladder type steel tube BodyaluminumFront and rear suspensionIndependent front and rear, with A-arm, transverse springs, Koni tube type adjustable shocks, anti-roll (sway) bars front and rearTire typeGoodyear Stock Car SpecialTire Size Front6.70 x 15"Rear8.20 x 15" WheelsMagnesium alloy rims, front 15.0x6.0", rear 15.0x8.0"![]() Curb2,300 lbs.Test2,430 lbs. ClutchTypeSingle dry discDiameterActuationMechanicalTransmissionTypeBorg Worner T-10M Four speedRatiosFirst2.32:1Second1.69:1Third1.29:1Fourth1.00:1 BrakesFront11" Girling discsRear10.0x2.5" drum Steeringrecirculating ballSix cars were built, only five are accounted for. The first car, CSX2287, has not surfaced. (New information, this car has been located, read the story here.)The Cobra Daytona Coupe information was collected from many sources, all resources are listed on the books and publications. Last edited by MustangOne : March 13th, 2008 at 01:33 AM. |
#50 |
1979 mustang 5.0
Wait mustangone, are you saying that the 65 Daytona Coupe had a 390 engine?? or are you just showing the specs? Your wording is " The 1964 / 1965 Daytona coupe was a 390 hp@6750 rpm" so you just have me a little confused........ it was a 289, but i guess it only turned to 7000rpms...
#52 |
1966 Vinyl Mustang
mustangone you've done a similar build on a 331 before producing 400hp? im just wondering because i ran the specs on a dyno simulator and it showing 370hp peak
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in the Garage McCain/Palin 08 |
#53 |
12.6 @ 114.3
lol, Vinyl... You make me laugh...
The build that I show you is the most you can get out of a 302, and drive it to school still, for under 3k. Now if you really want to get over 400 hp all you have to do is spary it. 75hp shot would be fine on this build. But with all good power, you will find the weaks links in your drive line. |
#54 |
1966 Vinyl Mustang
what can i say i guess everything i say is funny
#55 |
12.6 @ 114.3
We have alot of guys that are Looking for power on a budget.
This build Ive told you about is one that we have built 3 time now. For a little motor its alot of fun. I have this same build in my Lime Green 1965 Fastback Mustang. and it is a 347 Stroker. If you have drove a car with over 300 Real hp you will know that its alot of power for a car that dosnt have room for rear tires. My 65 have 245/45/17 on the rear of it and it just spins. With 347 Stroker cooling is a issue in a 1965/66 radator is just to small. With the 331 the bore is only .30 over witch is the biggest you need to bore a 289/302 for a 65/66. If you like you can pick my brain for anything else you need to know. I just like for you to get what you like out of your car and know what all is involved in it befor you send your money. |
#56 |
on page one i suggested the 347 stroker kit.they didnt listen to me either.i have been building for 40 years and that kit is rad if done right.i agree with mustangone.
#57 |
Car Craft had a good article on getting 400 HP out of a stock cammed 302 by only adding Heads, Headers, And Rocker Arms.
Ford 302 V8 Engine Buildup- Car Craft Magazine
1966 Mustang Coupe Ford Racing 5.0 HO Roller Motor/B303 Cam/1.7 RR TFS TW 205 Heads/Ceramic Coated Tri-Y Headers Edelbrock Performer RPM/Holley 650 DP 8 qrt Milodon oil pan/Griffin aluminum radiator Mallory Distributor/MSD/Holley Electric Fuel Pump 2.5" Exhaust with H pipe/2 chamber Flowmasters Auburn 3:55's rear/Aluminum drive shaft + loop SSBC disc brakes/C-4 wTCI 2800 15x6/15x7 Torque Thrust D's BFG Drag Radials Fiberglass Shelby hood/frt valance/trunk/bumpers |
#58 |
1965 Mustang Fastback
#59 | |
1966 Vinyl Mustang
who wasn't listening? i just wanted to know if it could be done with stock displacement. and i was asking specific questions on the stroker build from mustangone
#60 |
i here you vinyl.if you cram that kit in your car,hold on to your draws.
Threads Similar to: 400hp 289?
| ---Have 5 grand want 400hp--- | WTFJayJay | 5.0 Mustangs | 117 | August 27th, 2007 05:12 PM |
| new m3 v8 powered...400hp+ | jat | 2005+ | 7 | April 21st, 2007 11:11 AM |
