LinkBack (1) | Thread Tools |
#21 |
460 in a 66.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS 66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project) 03 Viper, Supercharged |
#22 | |
#23 |
theres a few problems associated with the 460. if you are able to fit it in, the 64,65,66 mustangs are not designed to handle that much motor.. besides the weight you will have major problems with both axle wrap and the frame twisting. its just not a wise choice, the biggest motor i would ever go with is a 390, usually not even that.. a built small block motor is all the motor you need in one of those mustangs
#24 | ||
Edit: major surgery I suppose is an opinion. The shock towers are pushed back a little, well, I guess about 3" at the base above the upper control arm. theres a lot of reinforcement into the front chassis too. I don't see anything wrong with putting a 460 in a 66 personally. Sure its hard on the frame, just reinforce it. I don't think I'd ever put a 460 into my 66. I'm just saying, it can be done. oh, gotta add, I do not know anything about that picture. I found it online and thought it interesting enough to save it. I don't know the owner or what he was thinking at the time.
#25 | |
Sorry, the picture didn't show up for me when I posted that. There is alot of modification done that's for sure. None the less I see now that it is possible.
#26 | ||
#27 | |
#28 |
Classic Moderator
In a 1968 Mustang with a 390 you had to jack up the motor to just to change the plugs.
Classic Mustangs are the best! Get one. |
#29 | ||
Not a big block but here's my test fit: ![]() Sorry to take this a little off topic. That is the 351w I blew up at the track now so dubbed the mock block, and my 351c heads. The heads I picked up were already prepped for a B302/Clevor application and machined for those exhaust port adapters seen in the pic. Those adapters make it even tighter when trying to change the plugs. I think without them I wouldn't needed to worry about plugs, but I have a header clearance issue too. I'm using 351c conversion headers to plumb the clevor, it did take some monster garaging to get everything to line up.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/6155-big-blocks-64-65-66-mustangs.html
| Big Blocks In 64, 65, 66 Mustangs | This thread | Refback | April 7th, 2012 09:28 PM | |
Threads Similar to: Big Blocks In 64, 65, 66 Mustangs
| 302/351 blocks | sleepinggt | 5.0 Mustangs | 4 | September 16th, 2007 11:48 PM |
| Engine Swap: Small Blocks or Big Blocks | Speedstang302 | 5.0 Mustangs | 32 | April 15th, 2007 10:34 AM |
| Anyone Know About Stock Blocks? | 89GTCONV | 5.0 Mustangs | 8 | March 31st, 2007 03:46 AM |
| old 302 blocks? | bwb3 | 5.0 Mustangs | 19 | March 24th, 2007 01:48 PM |
| 4.6 blocks | beheivjer | 96-98 | 1 | January 19th, 2007 11:36 AM |
