Lots Of Questions! Please Help!
Old October 13th, 2006, 06:44 PM   #1
DB67 is on a distinguished road
I pulled my straight six out of my 67, but have been looking for some good deals and ideas on new intake, headers and exaust, and carb. for the carb im thinkin bout a triple 1bbl, headers i want dual, and no idea about intake. i am also looking at milling my head, is it worth it and how much is safe? at what power output will i have to change from a 4 lug to a 5 lug wheel? if that is nessasary, where to look for that.
Also, my engine is in good condition, 49,000 original miles. (i dont know if this info will help with ideas of what to do)
Thanks for the help!!
Old October 13th, 2006, 11:12 PM   #2
Jamison42166 is on a distinguished road
www.fordsix.com
Old October 13th, 2006, 11:20 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can't get an intake for the 200 straight six because it is cast as part of the cylinder head. You could make a carb adapter for a Holley 500cfm two barrel and build a header for it. Milling the head will raise the compression a bit. You could have the machine shop install some larger valves right away and then you could do a mild port job on the head. I'm sure you could find a little bit bigger cam for it too. 200 horsepower should be attainable.
Threads Similar to: Lots Of Questions! Please Help!
My First Mod Need Lots Of Help Narcotics V6 Mustangs 24 November 29th, 2007 11:03 PM
lots and lots of miles... rednsilver91 The Clubhouse 25 October 14th, 2007 08:06 PM
lots of paint questions johnbarberr Visual 6 September 5th, 2007 06:54 PM
needs lots of info... jat 2005 - 2010 22 July 4th, 2007 01:19 AM
Lots of Work to Do. Slicey 99-04 6 March 22nd, 2007 03:59 PM
