Discussing AJE Racing front suspension kit in a 67 mustang in the Classic Mustangs Forum. We will be installing AJE racing's tubular K-member, A-arm, Coil over kit ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
AJE Racing front suspension kit in a 67 mustangpic of the car ![]() pic of the stock engine bay ![]() what it will look like with the AJEracing front suspension: ![]() link to magazine shoot in PHR! Richard Evans' '67 Ford Mustang - Popular Hot Rodding Magazine |
1967 Mustang Deluxe
damn work is blocking the pictures. I will have to check it out later as I was considering this for my 67.
pulled off the upper and lower control arms, steering, shocks, struts, steering box... and all the other misc crap that isn't needed any longer
![]() ![]() When I get up the nerve I cut the towers
1966 Vinyl Mustang
kick ass
your 67 is really badass
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in the Garage McCain/Palin 08 |
you dont need nerve.gra a cutting tool.
i sixing 200 six with 300 hp. |
one last look before I start cutting it up
![]() I ended up using a sawz-all and plasma cutter to get most of it out, I still need to fine trim up everything use the spot weld remover and the air hammer. went ahead and made a template out of cardboard and used a paint pen to mark the towers ![]() ![]() ![]() ![]()
precut looks good,and something tells me thats not a stock converter hanging there.keep on keeping on.
haha, no its not
here are some more pics the stock upper spring plate holder needs to be removed for the new caster camber plates to able to be installed ![]() ![]() using 14 g. sheet of material, made a template and cut out part of the plate using a plasma torch to overlay the tower. ![]() ![]() welded the plate from the inside the tower under the fender ![]() picture of the plates welded on ![]() here is what the finished product will look like and the tower smoothed! : ![]() next step is steering... our 67 has a 1 piece steering shaft and box so we had to cut it.
Remove the stock crossmember and bolt up the k-member to the frame using the second hole in from the back to line up the k-member. we put in inserts into the frame so the frame doesn't bend when attaching the k-member in.
drill, insert, tack weld or weld. ![]() ![]() ![]() assembly of the a arms, struts ![]() tighten with a torque wrench to 65lbs and blue lock-tite the strut retainer needs to be rounded off otherwiseh it will hit the inner side of the coil over and make a nocking noise ![]() the aje kit laid out prior to install ![]() k-member installed ![]() bolted up to the inserts ![]()
new caster plates installed
![]() installing the strut and installing the screw in clamp and coil springs ![]() installing the pinto rack along with the clamp for the rack from aje ![]() ![]() Since I went with the SN95 spindle assembly I put on the hub from a set of Cobra calipers and slot/ drilled rotors ![]() ![]() if you do the front you might as well do the back right! ![]() column modified ![]() installing the D-shaft ![]() had to go from a front sump to a Rear sump pan. We had to get a certain pick up tube to clear the stud girdle and nock a little dent in part of the stock 90's pan for it to clear along with weld in a bung for the oil drain from the turbo. ![]() engine reinstall ![]() header install... look at all that room. I could of installed the headers on the block then installed it but we didn't want to chip any of the paint. ![]()
hot dog.!!!!!!! nice peice of work man.
awesome car!
thanks guys.
here are some completed pictures, still need to take some more suspension pictures. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Threads Similar to: AJE Racing front suspension kit in a 67 mustang
| Front Suspension | dwmb25 | Classic Mustangs | 0 | February 24th, 2008 08:31 PM |
| front suspension is on! | mixedbreed02gt | 99-04 | 13 | February 10th, 2008 01:14 PM |
| Front Suspension Help? | JONJON | 5.0 Mustangs | 6 | December 14th, 2007 01:07 AM |
| Front Suspension | 01dutchGT | 99-04 | 1 | December 7th, 2007 02:20 AM |
| front suspension | whiteboycustom | 5.0 Mustangs | 25 | November 6th, 2007 06:52 PM |
