Discussing Removing pistons - force them past the cylinder ridges? in the Classic Mustangs Forum. I am tring to strip my 302 block prior to taking it to a shop ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Removing pistons - force them past the cylinder ridges?There are pretty tall ridges at the tops of the cylinders. Can I just force the pistons out past them, or should I try to scrape them down with a razor blade or something? My first engine rebuild, you understand. |
2000 Mustang V6 n proud
13.1@107mph 2.1-60'
take a piece of wood and just hit the connecting rod till it comes out
if your replacing the connecting rods then you wont need the wood you really wont even need anything to hit it unless the cylinder wall and piston are in bad shape. also if your rebuilding a motor at least have the walls honed and hexd
![]() 390rwhp V6 mustang stock bottom end |
You should pull the crankshaft and pull them out the bottom. Let the machine shop deal with the ridges.
If not get a ridge reamer from autozone or harbor freight. A ridge reamer is a special tool to remove the ridges. |
#4 | |
ridge reamer is the way to go and if the ridge is real bad get ready to have the block bored and buy new pistons, don't take a hammer to the rods bad idea. hope this helps RED
if you hammer on the rods,you will have to have them redone.money,money,money.
i sixing 200 six with 300 hp. |
Threads Similar to: Removing pistons - force them past the cylinder ridges?
| Pictures of Cars Past and Present... | ChrisJ | The Clubhouse | 82 | March 11th, 2008 11:29 PM |
| America's Past Time: Fighting | jdansby1 | The Clubhouse | 10 | December 7th, 2007 01:15 AM |
| Dallas O'Reilly Car show this past weekend. | 302 Deja Vu | The Clubhouse | 48 | August 18th, 2007 10:05 AM |
| 11.44 pass at Pinks All Out this past weekend | 1SLO85 | Videos | 10 | March 20th, 2007 12:26 AM |
| Past Vehicles And New Project Photoshow | 03svtsnakevert | Videos | 13 | November 14th, 2006 08:50 PM |
