car wont Stay running
I took my heater box out a week ago, replaced hoses and resealed the heater box and put it all back together. Now before this, the car was running strong but now since i got it all back together the car wont stay running. The timing and carb wasnt touched. Im baffled on what it could be. Im thinking maybe bad gas, not enough gas cause it is on low.
Its a 65 mustang with a 302 4 barrel carb
2001 mustang gt 5 speed Full bolt ons with 4.10 gears. 1965 Mustang 302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter. In the process of restoring it... |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Have you added any more good gas to the car yet ?
A: Does it only start while hold the key to start and die when you let off the key? B: Start and then keeps running but wont idle? C: Starts & Idles but cant give it gas ? |
it will run but won't idle
did you knock a vacuum line off the engine?
i sixing 200 six with 300 hp. |
does it idle real high or kinda revs up an down?
Look Ma! My First Post!
Check
1) The PCV hose. 2) If you have an automatic the hose that connects to the automatic kickdown 3) If you have vacuum advance that vacuum line 4) Check to make sure all of the vacuum connections on the carb are either connected or plugged. --- If those are all good then your problem may be a unlucky event unrelated to your heater repair. Then it is either a fuel or spark issue... - when it dies check to see if the carb still has fuel. - Check to see if spark is still going. |
It ran fine once i put new gas in but im still goinng to make sure all the vacume lines are connected or plugged. Thanks guys
so did you ever try putting in more gas?
It was just the quality of the gas because i had about a 1/4 of a tank of old gas. Drained the old gas and put new in and has been running good so far
Threads Similar to: car wont Stay running
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| Car Wont Stay On! | Eod | 96-98 | 27 | August 28th, 2011 05:58 PM |
| Car wont stay running | Spiderz | Classic Mustangs | 10 | March 8th, 2008 08:14 AM |
| wont stay charged | itsmyfiveoh | 5.0 Mustangs | 1 | June 22nd, 2007 03:26 AM |
| Stang wont stay running, after warm up...???? | ttop5.0 | 5.0 Mustangs | 2 | November 28th, 2006 04:10 PM |
