Discussing 351W bore size in the Classic Mustangs Forum. No problems at 4.040 bore on any windsor unless you have one with extreme ...
Old April 18th, 2008, 02:06 PM   #21
No problems at 4.040 bore on any windsor unless you have one with extreme core shift on the cylinder. I build em at .030 and .040 weekly. As for piston choice there is plenty of choices, your choices are narrowed as you will be using something with a 1.235 or 1.280 compression height. Do the math on whatever rotating assembly you buy as the 69 block is 9.480 So a 4 inch crank 6.200 rod and 1.280 piston stack is 9.48.
Old April 20th, 2008, 10:55 PM   #22
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Well, I got a block today, so let the madness begin
After I get the block to the machine shop, I'll be ordering my Scat stroker kit, and then it'll be a set of AFR 205s. A few thouand later, and some valvetrain parts, and I'll be running a little stronger.
Old April 22nd, 2008, 11:26 PM   #23
weird I would imagine it running cooler with thinner walls, shows how much I know
Threads Similar to: 351W bore size
bore Iownastang 5.0 Mustangs 11 February 5th, 2008 10:18 PM
Tap size for 351w where bell housing bolts up? 8A_Honda 5.0 Mustangs 2 August 5th, 2007 12:08 AM
head bore? sniperrider 5.0 Mustangs 4 June 4th, 2007 05:01 PM
stock bore Stock 5.0 Mustangs 1 January 7th, 2007 12:56 AM
Bore Size cali 5.0 Modular Mustangs 8 November 1st, 2006 02:00 AM
