Discussing 351W bore size in the Classic Mustangs Forum. What would you consider being the most you can safely bore a 351W block? I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1969 Mustang Mach 1
OLDNSLO
351W bore sizeI am going to build a pretty healthy 408, and I found a 69 351W block, but it's already bored .030, and it'll probably need to be punched again so it's fresh. I was looking for a 69 or 70 block because of the nickel content, but I'm not sure about going .040. Thoughts?
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
1968 GT 500 Super Snake
12.6 @ 114.3
If you like you can buy P.A.W.'s 418 Stroker Motor short block for $2400.
Comes with a, New Crank New Rods New pistons New Cam New Oil pump .30 Over Block Im building the same motors for my customers. Its a Great buy for the money. You can get the world product windser SR 202 heads for $449 each Assembeled. .40 over is fine, The problem is there is not a good choice of pistons for .40 bores |
#3 | |
1969 Mustang Mach 1
OLDNSLO
Thaks for the info.... Who's P.A.W? I was really planning on doing it all myself, but that's a pretty fair price. I'm going to use my own custom grind cam, and I plan on using AFR 205s. I'm shooting for 500bhp N/A. Sorry I didn't make it out there the other day. We were late getting in because of that weather we had, and we had to drive the pasengers. I'm up there a lot, so maybe next time I can swing by.
12.6 @ 114.3
Its All the parts to build a short block. You have to assemble it still.
The Part Number is #SPFORW420 Price is $2395 The Cam I use is Comp Cam COM-35-226-3 .512/.512 280/280 110 LC $115.95 You can order one of their catalogs, there $5 and look like a phone book. 818-678-3000 ![]() You can come by anytime when your in the area. I always have a small car show going on here. Next week we will be building the 418 storker here ourselfs again. The weather was not good at all to fly in im sure, the wind was bad. |
1966 Vinyl Mustang
fordstrokers.com has 351 408 kits for up to .060 bore
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in the Garage McCain/Palin 08 |
1969 Mustang Mach 1
OLDNSLO
I know I can get the parts, but I was more concerned with the normal problems from punching one out a little too far.
#7 | |
1990 Mustang LX
9.36@143 mph
It depends. 99% of the pre 80s blocks can go .060. Some of them can go bigger than that. I have one that can go 4.100 safely which was the block out of my black car. I have a 425 rotating assembly with all of the best forged and lightweight parts for cheap The crank and rods are used and the pistons are new dished pistons for pump gas.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#8 | |
1969 Mustang Mach 1
OLDNSLO
Really? So you think there would be no problems with .040 on a 69 block then?
1990 Mustang LX
9.36@143 mph
I haven't seen a 69-74 block that can't go .060. Those are some thick blocks. I've done alot of 75-77 blocks .060 as well.
12.6 @ 114.3
The only thing bad about going to .060 is the heating problems of the Driver that you want to run air on. The 69 mustang can run a good radaitor. The bad thing is a .060 block, It will be the last time it is built. If have never seen that big of a diffrence of the performance side to justify the extra .030 for the trade of the extra heat. Just because you can go .060 dosnt always mean you should.
I dont belive your building a drag racer, just and nice thumping sonic ride that you can thrash if you like. Right? |
#11 | |
1990 Mustang LX
9.36@143 mph
There will be no extra heat if the block sonic checks out ok. If the block is thin enough to generate extra heat boring it that far it will be too weak for racing as well. I've built many street only engines that needed to go .060 to clean up. Heat has never been an issue, even with a stock cooling system.
1999 Danger Ranger
its a 4 cylinder wit 8 spark plugs....
forget all of that dude get the 428 stroker kit they just came out with cant remember who made it but its sick my uncle jus stuck 1 in his 1970 mach 1 and the motor has over 600 hp+
![]() MM Mach 1 Crew (founder) |
for .060 make it up with pistons.that will save your block.
i sixing 200 six with 300 hp. |
12.6 @ 114.3
A .060 over motor 302/289 will not run cool in a 1965/66 drive in Texas in July with A/C on , driving in traffic. But a .030 motor will.
the thinner you make cylinder walls the more heat that transfer to the water, more heat you have to remove. Bigger cooling system you need. My point on this I like to Drive my cars in the summer and not worry about it getting hot. You may not share my veiw. That is ok. |
1969 Mustang Mach 1
OLDNSLO
I have no intentions of going .060. It's .030 now, and it will need to go to .040. I was just asking if Darrell was saying it's ok to go to.060. Just because you can, doesn't mean I will.
#16 | |
1990 Mustang LX
9.36@143 mph
12.6 @ 114.3
The main thing the answer to the Questions is yes, a .040 Block will work fine. there is not as big of a choice of pistons as there is for a .030 / .060 ,
In my opinion, In the older cars with max size 24" radaitors. I would not shoot my wad in a .060 motor if I didnt need to. Most of these people that read these treads dont have to money to re do a build if it runs hot in the area and for thier uses. |
2007 Mustang GT
Location: Northwood, ND...yes, hell does freeze over...
I might be reading it wrong, but there are engine builders doing a 4.125" bore on a 351w, combined with a 4-ish" crank to get 427 cubes...how much cylinder wall does that leave?? Not sure what that translates to as far as an over-bore is concerned.
myspace.com/grabber523 2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop Last edited by Grabber523 : April 16th, 2008 at 11:25 AM. |
1990 Mustang LX
9.36@143 mph
That is with an aftermarket block. I've only seen a two production 351W blocks that can go 4.100 and never seen one that can go bigger than that safely.
2007 Mustang GT
Oh...okay, good info. I'm looking at dropping a 427 small block in my 69 when the time comes. Thanks.
myspace.com/grabber523 2007 Grabber Orange GT Premium 5-Speed, CDC Sequential Taillights, 2.6L Kenne Bell, 3.73 FRPP Gears, Steeda Tri-Ax, Dynotech Alum. D/S, BMR D/S Loop |
Threads Similar to: 351W bore size
| bore | Iownastang | 5.0 Mustangs | 11 | February 5th, 2008 10:18 PM |
| Tap size for 351w where bell housing bolts up? | 8A_Honda | 5.0 Mustangs | 2 | August 5th, 2007 12:08 AM |
| head bore? | sniperrider | 5.0 Mustangs | 4 | June 4th, 2007 05:01 PM |
| stock bore | Stock | 5.0 Mustangs | 1 | January 7th, 2007 12:56 AM |
| Bore Size | cali 5.0 | Modular Mustangs | 8 | November 1st, 2006 02:00 AM |
