Discussing College Kid Question in the Classic Mustangs Forum. I have some long tube headers but they are old and kinda rusty looking I ...
Old April 28th, 2008, 04:36 PM   #21
CR70fastback's Avatar
I have some long tube headers but they are old and kinda rusty looking I am getting them refinished is that worth it. Will that help with the cam?
http://memimage.cardomain.net/member...619_7_full.jpg
You know its all about the gurth these days...
Old April 28th, 2008, 04:49 PM   #22
nba1341's Avatar
1965 Mustang Fastback
Originally Posted by 460brevill View Post
cam and gears will tripple what headers will do.
+1
C70fastback what type of rear end do you have?
I'm a good boy now.
slow car club - crew member 7 of 9
Mood: Cool
Old April 28th, 2008, 05:07 PM   #23
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
The Cam is not the novice Mechanic Id say
Comp Cams COM-35-414-3 .500/.500 270/270 LC 110 $119.95
1,800 - 5,800 Mild Rouge idel Stock Converter.
Headman Headers HED 88660 $149.95
3:50 Gears SUM-740901 $139.95
This set up will do you just fine.
The Cam and rear end gear you will need help with, to install
Good Luck
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old April 28th, 2008, 05:31 PM   #24
nba1341's Avatar
you might want to get posi if you get gears otherwise there might be no point
I'm a good boy now.
Mood: Cool
Old April 28th, 2008, 05:34 PM   #25
MustangOne's Avatar
12.6 @ 114.3
If he had more than $600 Bucks We could do all kinds of thing.
Think 579.95 For posi would blow our budget.
www.Mustang1.Com
Old April 28th, 2008, 07:10 PM   #26
69fastback's Avatar
That cam would be a good choice, and wouldn't take a lot of other parts to make it work. You would probably want someone who has done some cam installs to help out.
Old April 28th, 2008, 09:01 PM   #27
Do you need any other equiptment to install a cam like that?
Old April 28th, 2008, 09:06 PM   #28
MustangOne's Avatar
12.6 @ 114.3
That Cam is clam enough to use with what you have already. Just Remember it uses a 351 firing order
www.Mustang1.Com
Old April 28th, 2008, 10:23 PM   #29
Is their any piece of this that is easier to do or should be done first before the rest?
Old April 28th, 2008, 10:25 PM   #30
Why would you change the firing order? Is that what this cam runs?
Old April 28th, 2008, 10:30 PM   #31
Do you have to remove the engine??
Old April 28th, 2008, 11:44 PM   #32
Hey guys does all of this need to be done with a new cam?
Always install new lifters with a new or used flat tappet camshaft. Roller lifters may be reused with roller camshafts only after careful inspection for excessive lifter wear. Always use valve springs that match the camshaft manufacturer's requirements for open and closed seat pressures at the correct installed height. Other valvetrain components may be required (screw-in rocker arm studs, pushrod guideplates, hardened pushrods, special distributor drive gear, etc.), depending upon the profile of the cam you choose.
Thats what summit said and seems expensive
Old April 29th, 2008, 12:16 AM   #33
nba1341's Avatar
You definitely would need to change your valve springs with a new cam
and i would probably do the cam first over gears since you can't afford the posi
trust me with the cap it will just freakin jump at shifts its amazing like and you will fall in love with your car and its sound too
i used to love my car and after the cam i still love driving it and hearing it everyday when i wake up in the morning
now these guys will answer your other questions
I'm a good boy now.
Mood: Cool
Old April 29th, 2008, 09:01 AM   #34
MustangOne's Avatar
12.6 @ 114.3
??? nba1341 you lost me ???
Stock Ford Single valve springs are just fine up to .540 Lift.
No you dont need to remove your motor. Replacing your cam is a job that should be done by someone that knows how to do it. Yes Lifters need to be be replaced, and while you are there might as well replace your timing gear set.
The Rearend is something that needs to be done by somone that knows how.
To bad you dont live close to us. I have a 17 yo 1970 FB own over today doing this same things to his car at our shop. We let him do his own work while we watch over him. Its a great way to learn.
www.Mustang1.Com
Old April 29th, 2008, 11:05 AM   #35
Ok so that the springs are ok what kind of lifters would you need for this swap I am really getting into some uncharted waters now. Timing gear set? I know what a timing gear is but changing the whole set and adjusting it wow......
I am planning on only doing the cam for now when I get done with finals in a week and half. I would like to have all the stuff order b4 I get home.
I have my uncle who worked on race cars for this local guy and a chevy guy who loves to help out so I bet between the 2 I should be ok but I am clueless on what to buy when it comes ot lifters and timing sets
Old April 30th, 2008, 11:22 PM   #36
MustangOne's Avatar
12.6 @ 114.3
I would go talk to your local friends, They will be glad to help you im sure.
Good Luck
www.Mustang1.Com
Old May 1st, 2008, 09:36 AM   #37
with todays oils be sure to use a good cam break in additive,and run at about 22 hundred rpm for 30 minuts.
i sixing 200 six with 300 hp.
Old May 1st, 2008, 11:45 AM   #38
thanks guys I appreciate it
Threads Similar to: College Kid Question
Question about college.. Tiller88 The Clubhouse 16 April 10th, 2008 04:04 PM
Another College? Tiller88 The Clubhouse 50 April 6th, 2008 02:43 PM
Who is in College? AtlanticBlue99 The Clubhouse 40 November 20th, 2007 04:40 PM
College smoke-em The Clubhouse 22 November 5th, 2007 07:00 PM
Anyone In College GT 849 The Clubhouse 18 January 8th, 2007 01:05 AM
