Discussing best mounts for my 302 in the Classic Mustangs Forum. Currently doing a 200 302 swap and was wondering what the best motor mounts and ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1966 Mustang
best mounts for my 302 |
1968 GT 500 Super Snake
12.6 @ 114.3
if you have less than 350 hp stock motor mount are fine.
your tranny mount be the same as the one you have now. V8 frame mounts are $99. Stock rubber mounts are $11 each. The big question is what you do with your 4 lug stuff ? That is were the money is going to go. |
1965 Mustang Coupe
MustangOne is right, you need to get a new spindle and hub, 5 lug, for v8 mustangs, as well as all new front v8 suspension, and to get the 5 lug on the back a 9 inch rear end is what ya need. For the tranny mount you need a plate to bolt into place that extends your original mount, can easily be hand made. Thats just for starters on what you will need for that swap
1967 Mustang Coupe
Building her still...
Yeah you could also use a 8 inch rear thogh as well, Most of your money is going to go into getting 5 lug and your suspension. Like Mustang said
1966 Mustang
ok just to clear it up, I am going to need the frame mounts and the actual motor mounts?
and just for reference, the motor is putting out 365hp on the dyno. so should i spend the money on the polys or will the stock ones work fine? |
12.6 @ 114.3
yes there is 2 parts you need, Frame Mounts for a V8, & Rubber to motor mounts V8.
If your are drag racing every weekend Polys, If your just driving Stock be fine. What are you doing with the rear end? and Front End ? The stock 4 lug 6cyl Rear End will handle 200 HP. The stock front end Drag link and tie rod ends will not last long with extra wieght of the V8. Good Luck |
1966 Mustang
Sounds good, I ended up getting the stock stuff since this is my show and go car...not a race car.
As for the other stuff, I have a line on an 8inch rear, and if that falls through i will just look for another V8 rear out of a 65 or 66. The front spindles are the only thing that I need for the front end, and brakes of course. The rest of the stuff I am just replacing with stock 289 parts from CJs. Any suggestions would be greatly appreciated, this is the first time I have attempted a 6 cylinder to V8 swap. |
Threads Similar to: best mounts for my 302
| what mounts to buy | flattusmaximus78 | 5.0 Mustangs | 9 | March 5th, 2008 08:53 AM |
| Are these mounts for a 5.0? | noyz25 | For Sale | 1 | February 25th, 2008 11:35 PM |
| motor mounts drop mounts.. | e3sean | 5.0 Mustangs | 9 | February 11th, 2008 01:22 AM |
| 87-93 motor mounts like new | ujslost | For Sale | 0 | November 7th, 2007 08:07 PM |
| MOTOR MOUNTS | javier351lx | 5.0 Mustangs | 2 | August 22nd, 2007 04:18 AM |
