Discussing Intake help in the Classic Mustangs Forum. I posted this in tech, but it hasn't seen much action, so I'll ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1969 Mustang Mach 1
OLDNSLO
Intake helpI'm in the process of building a 408. I'll be using a custom grind, hydraulic, roller cam, and AFR 205s. I'm going to try and keep the compression at no more than 10.5:1, and I plan on twisting around 6200-6300 rpms. It's mainly going to be a street machine, that will go to the track a few times a year, and it's not a daily driver, but I will be driving it quite a bit. Probably 10,000-12,000 miles per year, and it's a manual transmission. I'm looking for the right intake, and I want to keep the stock hood. I have a Weiand stealth on the 351W right now, and I was wondering if that would be a good choice for the increase in cubic inches? It's supposed to be rated from idle to 6800 RPMs on the 351, but I figure with those heads, and cubes it may not be sufficient for anything over 6000 RPMs. Thoughts? What are the thoughts on a single plane for what I'm doing? I know a lot of people don't like single planes for the street, but I already have hood clearnace issues, so something like an RPM air gap is out of the question, so would a single plane be a good compromise? I would really like to see in the 500hp range out of this. Any help is appreciated.
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
that weiand should be fine.the most it could cost is a gasket set if you dont like it.i would try it.i would also port match it.
i sixing 200 six with 300 hp. |
June 08 ROTM
1968 GT 500 Super Snake
12.6 @ 114.3
This is the one we use on our stroker motors, Very Nice all around performance.
![]() Edelbrock Performer RPM Air-Gap Intake Manifolds Intake Manifold, Performer RPM Air Gap, Dual Plane, Aluminum, Natural, Square Bore, Ford, 351W, Each $254.95 If you like you can come by and Drive the 408 Stoker 1970 Twister we built. This Next week we are building another 427 Stroker motor. Will will be firing it up Monday the 5/11 |
#4 | |
1969 Mustang Mach 1
OLDNSLO
#5 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
A Victor Jr. should fit under the stock hood. I had one on a 351W in my 65 Mustang and it cleared the stock hood. A single plane intake isn't going to have any effect on streetability as long as the total combination is matched. You will be leaving power under the table if you put a dual plane intake on it. I've run many single plane intakes on street cars with no problems. A good combination is going to run great regardless of what intake is on it. People say the same thing about high stall converters which are plenty streetable as well.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
#6 | |
1969 Mustang Mach 1
OLDNSLO
I've heard a lot of people say that single planes won't affect streetability, but I've never actually had one. It seems like you get a different answer from everybody you talk to. I honestly think that will be the best way to go, because of the clearance issues with a stock hood.
#7 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
1973 Coupe Mustang
pft if i know
i run a single plane intake on my 302 in my 73, never had any problem with performance or anything for that matter. an i dont think i have noticed any sufficent rpm range difference from a one plane intake to an dual plane intake
#9 | |
June 08 ROTM
12.6 @ 114.3
The Nice about when I say somthing you can come over a see and touch and Drive what you are looking to do. |
#10 | ||
1969 Mustang Mach 1
OLDNSLO
Really? What kind of air cleaner are you running. I have a 1" drop down, with a 14" air filter, and the lid hits the studs on my scoop with the Weiand intake that's on there now. I just don't see any way an air gap will fit.
June 08 ROTM
12.6 @ 114.3
June 08 ROTM
12.6 @ 114.3
That 408 Stroker Runs So Damn Hard.
TKO 5 speed Cal-traks Curry 9" 31 Spline rear end 3:55 Gears Eaton Traction Lock If you like, You can test Drive this car Next Weekend. |
1969 Mustang Mach 1
OLDNSLO
That's basically the same air cleaner setup I have, and like I said, it hits the studs on my scoop now.
I would love to drive it, but I'll be in LAX next weekend
June 08 ROTM
12.6 @ 114.3
Are you useing the 1" spacer Still? This one we are not. And we are using the same hood set you are. And it clears by a 1/4" Runs Great.
1969 Mustang Mach 1
OLDNSLO
I have a Holley street avenger carb, and no spacer. I plan on driving up some weekend and checking out your shop. I'll probably drive my car up there, and get some ideas from you.
Do you guys do your own body work there? I'm no good at body work, and my car is getting some rust in the usual places, and is going to need some work in the future.
June 08 ROTM
12.6 @ 114.3
We have 3 Trusted Body Shops that do all of our work. We have at least 12 cars a years paint at this time.
Threads Similar to: Intake help
| short ram intake or cold air intake????? j/w | Stangbro8994 | V6 Mustangs | 32 | September 18th, 2008 08:20 PM |
| S&B intake my intake on them ..........? | RanGer498 | Parts | 3 | May 7th, 2008 12:05 AM |
| Aftermarket intake vs Cobra intake... | Brent Russell | 5.0 Mustangs | 11 | April 27th, 2008 10:35 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
| Need help using a 5.0 upper intake on a 5.8 lower intake | Washington5.0 | 5.0 Mustangs | 4 | March 9th, 2007 01:54 AM |
