Valve train help
Old May 8th, 2008, 12:37 AM   #1
1973 Coupe Mustang
as fast as the restoration is going
Katen will become famous soon enough
Send a message via Yahoo to Katen
Valve train help
now i am wanting to build my top end up. meaning cams heads valves an so forth. now i wanted to know what all you guys have had an ran whom you trust an all that jazz. tring to get an idea of what is out there that has had some good luck with.
also could some one explain the like lift an all the other like statistics that come with a cam cause i am lost a lil bit on that.
also i have a 302 basicly stock
Thanks guys
Keith
Old May 8th, 2008, 01:18 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Cam : SUM-k3606 234/244 .520/.544 rpm 3400/6800 $89.95 needs stall converter on C4's Auto's
Carb: HLY-0-80670 670cfm $369
Intake: Air Gap EDL-7521 $239
Heads Procomp 190 cc $759
Adgressive camOperating Range:2300-6500 RPMDuration Advertised:284° Intake / 296° ExhaustDuration @ .050'' Lift:240° Intake / 246° ExhaustValve Lift w/1.6 Rockers:.541'' Intake / .544'' ExhaustLobe Separation Angle:110°
Clamer Cam
Operating Range:1800-5800 RPMDuration Advertised:270° Intake / 270° ExhaustDuration @ .050'' Lift:224° Intake / 224° ExhaustValve Lift w/1.6 Rockers:.500'' Intake / .500'' ExhaustLobe Separation Angle:110°
All we are trying to do here is get as much Fuel and Air Mix into the cylinder's.
Have the cam hold the Intake Valve open Longer & open wider While the piston is in it full down stroke so the Heads will flow as much cfms of air fuel mix into the cylinder.
Old May 8th, 2008, 01:38 AM   #3
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
Just Remember When we put more air in, We need a Better flow of air out.
Old May 8th, 2008, 01:50 AM   #4
1973 Coupe Mustang
i found a pair of edelbrock heads that had the valve size of a boss engine well 2v. the intake was 2.05 an the exhaust was i think 1.71. i am tempted to go with that. now the cam i want to be mild. an i already have headers carb i have an edlebrock 650 electrical choke. i forgot what intake i have. so with that valve size what cam would you sugest? an what kind of stall conveter would i need.
plus keep in mind for now i just want like 350 rbhp, an i think i can get close to that with the heads an cam an stuff. or is that pushing it?
Old May 8th, 2008, 04:13 AM   #5
1965 Mustang Fastback
nba1341 will become famous soon enough
its possible but you said rbhp
so did you mean rwhp or bhp ?
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old May 8th, 2008, 08:59 AM   #6
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
The problem with getting into stuff that big, is it will require more and more work. If you get valves that big with any kind of cam, you will have to have the pistons fly cut.
Cam profiles are very complex, and there's a lot more to it than just picking the ones with the biggest numbers. There are a whole lot of other things to take into consideration. Unless you're prepared to have to do a lot more than just install heads and cam, I suggest you stay a little smaller on the valve size.
Comp Cams is always a good choice for valvetrain parts on what you're trying to do.
My recommendation is to find a set of heads you can use (if you don't mind taking the engine to a machine shop and getting the pistons fly cut, the ones you mentioned are fine), and call Comp Cams tech line and tell them your combo. They will tell you which one of their cams will work the best for you.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old May 8th, 2008, 01:28 PM   #7
1973 Coupe Mustang
alright well then there is another set of edelbrock heads that have 1.91 intake an 1.60 exhaust. that would proly work better i take it.
so comp cams will customly grind a cam for me to fit what i want is what your saying. also for stock heads on a 73 302 what size valves do i have?
Old May 9th, 2008, 12:36 AM   #8
1973 Coupe Mustang
Edelbrock.com - Cylinder Heads - Ford - Small-Block - Victor Jr.
These are the heads i want the victor jr ford. reason being is for the 70 cc combustion chamber plus the high air flow it will provided. what do you guys think. also i already have a rebuild kit in mind that has valve notches or releifes in them
Old May 9th, 2008, 12:46 AM   #9
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
Those are great heads for what you're wanting to do, but valve reliefs being cut in the pistons are not the same as fly cutting them. Most flat top pistons have valve reilefs cut in them. The only way to be sure is to clay the pistons to check the piston to valve clearance, but I'm almost sure you'll have to have the pistons cut with a valve that big. Darrell could probably give more insight on that than me.
I was necessarily saying Comp Cams will custom grind one for you. They have many pre ground camshafts like the ones MustangOne posted, bet they can tell you which one will work the best.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old May 9th, 2008, 01:27 AM   #10
1973 Coupe Mustang
reason why i want these heads are due to finding the boss intake is a bitch. i wanted to build a 347 stroker with 351 cleavleand 2v heads but not going to happen. so these i found so where would i need to go to get the pistons fly cut as you put it?
Old May 9th, 2008, 08:41 AM   #11
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
Any machine shop.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old May 9th, 2008, 09:08 AM   #12
tom2000r is on a distinguished road
Thanks guys
Keith
call cams auto machine shop, in canton,ohio...or akron horsepower in akron,ohio.... or fox lake power products ,,in dalton,ohio...these shops are in my area.there all good building fords if you need phone numbers pm me......
Old May 9th, 2008, 04:31 PM   #13
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
i pulled the head off my i 6 31 times to cut the pistons,but it was worth it.
i sixing 200 six with 300 hp.
Old May 10th, 2008, 12:31 PM   #14
1973 Coupe Mustang
so just e range for the piston cutting how much usualy does that cost.
Old May 11th, 2008, 02:01 AM   #15
Kobra Killer's Avatar
Kobra Killer is on a distinguished road
You don't need to stroke a 351C to get 400+ hp.
Here is one in cincinnati
built 351c 425hp
Akron
351 Cleveland Engine
Cleveland
1971-72-73 Ford Mustang 351 Cleveland engine/parts
351 CLEVELAND -----=RARE=----------!!!!!
1973 mustang motor and transmission
Columbus
ford 351c & tranny out of 73 grand tarino 70,000 org miles
Circleville
351 Cleveleand High Output Motor
Pickerington
351 FORD CLEVELAND ENGINE
There are more out there if you want them
Clevelands Rule
https://home.comcast.net/~jimmiephil...er_project.htm
Old May 11th, 2008, 12:44 PM   #16
1973 Coupe Mustang
that is true but the fact being is i want to keep the original engine with this car. plus people are doubting i can get out that much with my engine setup i have in mind so i am going to prove them all wrong after it is done on the track. stupid ls1 guys make fun so i will beat them with my punny 302. so off the subject of getting a bigger engine in there it will stay the orgianal block so back to the topic.
Threads Similar to: Valve train help
Heads/Valve train Question 01ROUSH 99-04 20 April 14th, 2008 08:28 AM
Valve train noise on a 4.6l nolife 5.0 Mustangs 15 January 16th, 2008 10:33 AM
Cam and valve train??? flamed 98 gt 96-98 8 November 2nd, 2007 02:58 PM
Valve train clacking sound. Need help. Maxwell881 5.0 Mustangs 4 March 15th, 2007 02:44 PM
Valve Train Noise? superbeef1000 99-04 3 September 10th, 2006 08:42 PM
