Look Ma! My First Post!
dim dash lights on 67
My dash gauge lights are very dim. The wiring is good. Everything works fine except the dash lights are dim. Any suggestions to make them brighter? Can I use brighter bulbs and if so what numbers would work? Thanks
1967 Mustange Coupe, 200i
Something to think about is maybe you are not getting enough voltage to the lights even though the wiring looks fine. Just a thought...otherwise I don't know what numbers will work.
if volts are good,go to higher candle power bulb.
i sixing 200 six with 300 hp. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Just one thing to check first, Turn the knob to the left to see if they are set to the brightest setting.
If they are , Clean or replace the bulb covers. The bulbs are 1895's if all is set right and clean they are pretty bright. |
Sounds like your headlight switch may be broken-Dimming portion only. Alot of times, the dim "wheel" in the switch corrodes. It could be getting minimum volts from a corrosion problem. The switches are cheap and easy to replace. Good luck. Dont put brighter bulbs in. This has been known to cause a heat problem and melt wiring.
1964 Falcon Sprint 4 speed 1965 347 Cyclone 4 speed, B/FX clone 1993 Mustang Cobra (red/grey cloth) |
Admanistrator
ya try replacing the bulbs.
mustangone that is a sweet car in your sig. i hope its yours |
#7 | |
Lost in the 60's
12.6 @ 114.3
Yes both of those are mine. The Red one is me at the Daytona Speedway. |
66 Mustang coupe
Just installed LED bulbs into my dash lights and they are at least 3 times brighter. Here is the link for the Ebay site I got them from. If you are going to open up the cluster, you may as well do it with these and never have to change bulbs again.
Seller got them to me in 4 days and fit perfect. Many colors available and I went with the blue ones. Very cool. ![]() eBay Motors: 1967-68 Ford Mustang LED Gauge Light Conversion Kit TAC (item 190208719232 end time Jun-20-08 14:26:55 PDT) |
Threads Similar to: dim dash lights on 67
| Speaker Clicking Noise And Dash Lights Not Working | Lastofthe5.0's | 5.0 Mustangs | 5 | April 11th, 2008 02:01 PM |
| Dash lights just got knocked out | White Knight | 5.0 Mustangs | 2 | February 9th, 2008 11:14 AM |
| please help!! dash lights will not work | browningboy13 | 5.0 Mustangs | 30 | May 14th, 2007 12:31 PM |
| Dash lights | lissy | Audio/Video | 20 | March 13th, 2007 02:00 PM |
| Interior dash lights | Exseque | 2005 - 2010 | 6 | March 8th, 2007 01:51 PM |
