65 289 Vacume Advance issue
Old May 25th, 2008, 01:47 AM   #1
Rolfey is on a distinguished road
According to the manual the engine is suppose to run at about 10 degrees advanced however my engine runs at about 20. When we disengage the vacume advance and plug it, the engine correctly sits at 10 degrees however refuses to idle. Any ideas?
Thanks
Old May 25th, 2008, 10:06 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Sounds Like you have Valcuum Leaks Some were. Check Carb Base and all vacuum Ports.
On your timing issues your advance was working correct. you just dont start a 10 Deg you start close to TDC = Top Dead center, Then when it start running the advance moves the timing to 10 Deg.
Good Luck
Old May 26th, 2008, 06:51 PM   #3
65 B/FX is on a distinguished road
Thats incorrect actually for a stock set-up (unilite). Ive been working on SBF for 30 years and this is a common misconception. There is no vacuum in the line from Advance unit to Carb at idle. The initial degree should be 10 or so like you said, and a total of around 30 or so. It does sound like you have a leak either in your advance unit itself, or the line/connections to-from the unit. It sounds like the diaphram in the adv canister may be split. Try a new one and see. Is your vacuum line hooked up to the correct vacuum port on the carb? That could be as well. Again, there should be no vacuum at idle, so use that port on the carb. Hope this helps.
1964 Falcon Sprint 4 speed
1965 347 Cyclone 4 speed, B/FX clone
1993 Mustang Cobra (red/grey cloth)
Threads Similar to: 65 289 Vacume Advance issue
Vacuum advance whitefox89 5.0 Mustangs 3 April 16th, 2008 01:48 AM
vacume line greyauto02 V6 Mustangs 8 November 3rd, 2007 04:43 PM
Proper way to plug a vacume line??? jam77 5.0 Mustangs 5 September 4th, 2007 11:20 PM
Timing Advance MustangSparks 94-95 2 August 4th, 2007 04:47 PM
vacuum advance ttop5.0 5.0 Mustangs 0 August 26th, 2006 03:44 AM
