Discussing door won't open in the Classic Mustangs Forum. I have a 68 coupe. This week-end a replaced the screwa around the door ...
Old May 26th, 2008, 10:23 PM   #1
Look Ma! My First Post!
door won't open
I have a 68 coupe. This week-end a replaced the screwa around the door latch. I only had 1 screw in there and figured I lost the other 2. So I when down to the hardware store and got 3 screws that were close. The only difference is that the were probably an inch long. After putting them in, I shut the door and haven't been able to open it since. I've tried both inside and outside handles, but no luck.. Any help would be awesome. Thanks.
Keith
Old May 26th, 2008, 10:31 PM   #2
I Touch Myself Sometimes
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
your going to have to pry it open.. chances are that the heads on the screws are too big.
it happened to me in my 01 as well.
MILITARY CREW
FOUNDER
Originally Posted by DeMello View Post
i love hondas
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebands
email joe@tricktuners.com
Old May 26th, 2008, 10:39 PM   #3
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
D o . . . W h a t ? ? ? ?
Ok before we get CRAZY here.
All you need to do is Take the door panel off, and take a look to see what happened here. With the window up you can look at all 3 rods.
Outside Rod
Inside Rod
Door Lock Rod
Just make sure the door lock rod is in the unlock position.
then take a look at the other 2 rods and see if they are in a bind.
Good Luck
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old May 26th, 2008, 10:44 PM   #4
HMUSN's Avatar
19.83 @ 12mph
he said he put to long of screws in the latch..
nothing in the inside will help..
I bet you the new screws are hitting the frame.
MILITARY CREW
FOUNDER
i love hondas
Old May 26th, 2008, 10:49 PM   #5
MustangOne's Avatar
12.6 @ 114.3
Cool
If you knew how the 68 latch worked you would know that all the screw could hit is were the rod connect to the latch.
With the door Panel off you can open the door from the inside. Just need to see witch rod is in a bind.
www.Mustang1.Com
Old May 26th, 2008, 10:51 PM   #6
HMUSN's Avatar
19.83 @ 12mph
Well in that case I will subscribe to this thread and hopefully learn something new.
the only 2 mustangs I haven't owned were the 96-98's and the classics.
MILITARY CREW
FOUNDER
i love hondas
Threads Similar to: door won't open
Open Trailer monkeyman437 Other Stuff 5 April 9th, 2008 06:20 AM
can walmart cut a key to open the door? obdnanr V6 Mustangs 27 March 30th, 2008 09:46 PM
while it's open Jucostud 96-98 1 March 2nd, 2008 08:56 PM
Driver door lock is stuck. Can't open door Help!!!! White 89 5.0 Mustangs 9 February 28th, 2008 11:47 AM
Open 4 Suggestions;)? Mustang McLennan New Members Introductions 12 February 21st, 2007 11:14 AM
