67 not charging
Old May 28th, 2008, 12:33 PM   #1
67mustangconvert is on a distinguished road
67 not charging
I've got my project purring, but I noticed my battery is being drained while tuning it. I have a new alternator that a shop put on, when my engine and body work were being done.
What are some first things to check to isolate the problem. Mine was a 6 to 289 swap. Could my voltage regulator be bad, what else should I check?
Old May 28th, 2008, 02:09 PM   #2
1965 Coupe
zers is on a distinguished road
First thing I would do would be put another battery in it, see if it charges that one. if it doesn't, then you have a problem with .. well, something electical =p
http://i17.photobucket.com/albums/b57/mustangclint/SIG-Zers.jpg
Old May 28th, 2008, 06:57 PM   #3
battery's fine
Old May 28th, 2008, 09:20 PM   #4
1965 Coupe
I would pull out a voltmeter, and check the regulator, and make sure the alternator is installed correctly then.
Old May 28th, 2008, 09:33 PM   #5
bossman69's Avatar
1969 Mustang
N/A
bossman69 is on a distinguished road
Check voltage!!
First thing I would do is get a digital or anolog volt meter and check power at the battery before running.Should be at 12.0-12.6v varyies with battery.Next start the car and check again the battery. Should be around 13.5-14.0v depends on alternator.If you not getting this then check alternator,Put positve lead on postive connection on the back of the alternator and ground to the case of alternator or good ground.This will tell you if the alternator is putting out the right amount of voltage to charge the battery.Should be around the same as the battery if working right. Now if you are getting the right voltage off the alternator but its not getting to the battery,then make sure all wires on back are in the right spot ,if I remember right there should be just the harness that screws on and it only goes on one way.If all that is good then its got to be the voltage regulator.If the alternator isnt putting out what it should be then tell tha shop that put it on that its a bad alternator and repace it.hopfully that helps you.
Old May 29th, 2008, 01:57 AM   #6
supermachone's Avatar
2004 GT
Kessel Run @ Less Than 12 Parsecs
supermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to allsupermachone is a name known to all
yeah man, make sure they hooked the alternator up right..happened to me with my old camaro, brand new alternator but it wouldnt stay charged...alls that happened was they didnt hook it up right
but yeah check your voltage like bossman said, make sure all your wires are good and not shitty just start at one place and work till you find the problem
Old May 31st, 2008, 10:40 PM   #7
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
the two push on plugs on back of the alt. may be crossed.one red and one black.wouldnt hurt to check.
i sixing 200 six with 300 hp.
Old June 3rd, 2008, 05:04 AM   #8
Stangman558's Avatar
67 FB GT
Stangman558 is on a distinguished road
I agree with Bossman also. If it's not the battery or the alternator...got to be the regulator.
Perennial Mustang Student...
Threads Similar to: 67 not charging
Charging Problems? fast5liter 5.0 Mustangs 6 May 12th, 2008 06:31 PM
Alternator not charging jonnotch 5.0 Mustangs 2 March 4th, 2008 11:59 AM
charging WilltheThrill 99-04 5 January 27th, 2008 07:46 PM
charging help! pnyboi 5.0 Mustangs 3 May 7th, 2007 07:54 PM
Charging Problem... Please Help! cstmp8r Audio/Video 3 November 13th, 2006 02:47 AM
