toploader wide ratio, close ratio
LinkBack (1) Thread Tools
Old May 30th, 2008, 02:27 PM   1 links from elsewhere to this Post. Click to view. #1
SoonerStang's Avatar
SoonerStang is on a distinguished road
Question
Okay,
So I just picked up my toploader from being rebuilt, I have a 428cj as stated, and we picked up the toploader from a 390. The tranny is a wide ratio small in small out. While I understand it is technically NOT correct for my application, I can't really afford the 2500 for a big in big out short, close ratio. I have also been told that wide ratios are actually better for driving around town. SO RIDDLE ME THIS... and i should know it, but what is the difference and how does it work. I know the ratios and all that jazz, but i just cant seem to wrap my head around it and keep it around it.
Close Wide
1st gear 2.32 2.78
am I correct that the engine spins 2.32 times per 1 revolution of the transmission in the close ratio and 2.78 in the wide.
how does this help the daily driver?
SS
-1970 428 Mach 1
456 hp 4spd Tangelo Pearl
-2007 Mustang GT
Alloy Metallic
*(awaiting modification)
Hurst Crew Member No. 5
Old May 30th, 2008, 03:35 PM   #2
1965 Coupe
zers is on a distinguished road
2.32:1 means your engine is going to spin 1 time, and your transmission output will spin 2.32/2.78 times
http://i17.photobucket.com/albums/b57/mustangclint/SIG-Zers.jpg
Old May 31st, 2008, 04:05 AM   #3
theodoor24 is on a distinguished road
i believe sooner stang had it it right. so 2.32:1 means the engine spins 2.32 times per 1 revolution of the output shaft on the tranny.
Old May 31st, 2008, 01:05 PM   #4
I did the math on it last night and it seems that zers is right. the transmission and the rear end are reducers. when doing the math, at 6500 RPM in 3rd gear, i would be going approx 107 mph. That was with a 3.50 rear end, and a 10" wide 60 series rear tire.
i did the math but lost my post, so here it goes again.
RPM/transmission gear ratio/rearend gear ratio=tire rotations/minute
TireRPM*circumfrence of tire in miles*60 minutes----> Miles per hour.
the bad news is that i will have to shift to 4th in a 1/4 mile.
the good news is that the wide ratio transmission has a higher mph/rpm in first gear. The engine will be in its powerband for a longer period.
-1970 428 Mach 1
-2007 Mustang GT
Alloy Metallic
Old May 31st, 2008, 10:35 PM   #5
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
if you keep your rear tires to about 27 inches it should make good power.
i sixing 200 six with 300 hp.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/73515-toploader-wide-ratio-close-ratio.html
toploader wide ratio, close ratio This thread Refback October 12th, 2011 11:30 PM
Threads Similar to: toploader wide ratio, close ratio
A/F ratio?? 07 STROKER 2005 - 2010 8 April 21st, 2008 09:15 PM
C/R ratio viper3508 5.0 Mustangs 6 January 24th, 2008 06:27 PM
Compression Ratio scxc15 Modular Mustangs 4 September 25th, 2007 12:01 AM
what comp ratio for s/c? DJKING General Tech 7 April 11th, 2007 03:14 PM
Need help with the 3.55 Gear Ratio Lil_M Modular Mustangs 5 March 31st, 2007 11:22 AM
