Discussing weird noise!!! in the Classic Mustangs Forum. Got it runnin and it sounds good except for one thing. Ive got this popping ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1969 Mustang
N/A
weird noise!!!
Got it runnin and it sounds good except for one thing. Ive got this popping noise while its running.It was doing it alot while I was adjusting my carb and I thought I got it all right but every once in a while it popsw and I know for sure its not bad plugs or wires.It might be my distributer out of time or my be its the air/fuel mixture.Dont know but if I cant figure it out Im goint to change my dame intake and carb to a 4-barrel. I need a tach so I can set my idel and going to change my points to electric points by IGNITOR so I dont have to adjust it any more.
any Idea what it might be?The sounds coming from the end of headers.
1973 Coupe Mustang
pft if i know
just an idea maybe your valves arent sealing right. only think i can think of
2004 GT & 1972 Mach 1
Kessel Run @ Less Than 12 Parsecs
you sure its not backfiring through the carb itself?
2004 Screamin Yellow Mustang GT
1972 Yellow Mustang Mach 1 ![]() |
90 lx hatch
13.02@103.62
Is it open headers? If so are they long tubes or shorty headers?
to many parts and money to be so slow ![]() F/S 1986 mustang vert asking $6500 http://www.moddedmustangs.com/forums...ml#post1277818 |
67 FB GT
That popping noise
Hey Bossman,
My bet on that popping noise is that you will find you have a header leak. I check my header bolts (to the block) a few times a year because they have a tendency to loosen up....no matter how tight you think you got them. The other spot is at the collectors. A leak at either collector will produce a popping sound...and the type of popping is just a matter of how big the leak is. Unless you spend a few extra bones on the good collector gaskets, they get brittle after awhile and a good bump or scrape on a speedbump and they break at one spot or another. Just my two cents. Would like to know what you end up finding. |
1969 Mustang
N/A
Well tha car has been sitting for 5 years and Im pretty sure the gaskets are brittle but it would be makeing the noise all tha time.They are long tube headers. and when it pops it sounds like it echos through the muffler and its on the passenger side only.may be the valves are sticking and maybe it has build up from the old oil.I might take some SEA FOAM and run it through the motor first.Ill keep yall informed on what it is.
put half quart of atf in your oil.run it at about 2500 rpm for 20 minuts. see if it stops the noise.
i sixing 200 six with 300 hp. |
1969 Mustang
N/A
Ill try it tomarrow but until then stay tuned
Threads Similar to: weird noise!!!
| Weird noise | Eggman | 2005+ | 3 | March 17th, 2008 05:16 PM |
| weird noise? | ricerraper33 | Engine | 11 | August 11th, 2007 03:31 AM |
| weird noise | 3.8Coastie | V6 Mustangs | 19 | July 3rd, 2007 10:37 AM |
| weird noise? | mustang sallie | 96-98 | 4 | June 13th, 2007 12:23 PM |
| Weird noise... | Keegan_Vann | 99-04 | 19 | April 19th, 2007 05:12 PM |
