Discussing so a query. . . in the Classic Mustangs Forum. I'm planning on drilling out a broken intake bolt out of my head, what ...
Old June 13th, 2008, 12:09 PM   #1
707Stang's Avatar
1969 Coupe 302h.o.
Go Raiders! :P
so a query. . .
I'm planning on drilling out a broken intake bolt out of my head, what are some pointers or tips to be aware of? im planning on using a drill press and having the hole level up and down. i'm planning on soaking the bitch with penetrating oil.
Originally Posted by Hunt_chevs View Post
Buy a v8 next time
06 Eclipse GS-sex machine
ok, you're rowing your canoe...thru the desert, and the wheel falls off....what do you do?...quick, cook a turkey.....
Old June 13th, 2008, 12:30 PM   #2
atlacatl213's Avatar
2003 Mustang V6
SupaDupaSlow
invest in a set of bolt extractors?
Minutos que se burlan de mi
Minutos como fuego en la piel
Minutos que me duelen sin ti
minutos que no pagan pensión
minutos que se roban la luz
Minutos que me oxidan la fe
Minutos que se estrellan en mi....son camikases de Dios.
Old June 13th, 2008, 12:45 PM   #3
2003 Mustang V6
SupaDupaSlow
this is what i meant lol
Order Here!
Old June 13th, 2008, 01:29 PM   #4
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
I use Easy Outs.
They work great everytime.
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old June 13th, 2008, 01:29 PM   #5
707Stang's Avatar
1969 Coupe 302h.o.
Go Raiders! :P
oh i forgot to mention i already broke three easy outs the first time i tried this a couple yrs back. . .
Buy a v8 next time
Old June 13th, 2008, 02:52 PM   #6
Kobra Killer's Avatar
Soak in Marvel Mystery oil.
Drill pilot hole to fit largest possible Easy-Out.
Use carbide bit because these bolts are hard.
Work Easy-Out while tapping the end with a hammer.
The vibration helps break threads loose.
You might try an impact wrench if it has a low torque setting.
Also heating area around bolt sometime helps.
Clevelands Rule
https://home.comcast.net/~jimmiephil...er_project.htm
Old June 13th, 2008, 10:40 PM   #7
save your money.take it to the pros.cant cost that much,and done right.
i sixing 200 six with 300 hp.
Threads Similar to: so a query. . .
Exhaust query!! recoil50 Exhaust 3 April 19th, 2007 01:18 AM
