Discussing Flywheel installation in the Classic Mustangs Forum. I have an externally balanced flywheel. How do I know the right way to install ...
Old June 20th, 2008, 04:46 PM   #1
I have an externally balanced flywheel. How do I know the right way to install it back on the crank. There isn't a pin to line it up. This is for a 1967 Mustang 289 or 302
Old June 20th, 2008, 04:49 PM   #2
I just read another forum, I guess the bolt holes should only line up 1 way. Does that sound right?
Old June 20th, 2008, 05:46 PM   #3
1965 Mustang Coupe
Thats right, the holes should only line up one way, it might look like they line up another, but you wont be able to get the bolts in.
Old June 20th, 2008, 07:51 PM   #4
707Stang's Avatar
1969 Coupe 302h.o.
Go Raiders! :P
i don't know how long it took me to get that thing lined up!
Originally Posted by Hunt_chevs View Post
Buy a v8 next time
06 Eclipse GS-sex machine
ok, you're rowing your canoe...thru the desert, and the wheel falls off....what do you do?...quick, cook a turkey.....
Old June 24th, 2008, 04:32 PM   #5
Ron
66 Mustang coupe
The holes will only line up 1 way. This makes sure the engine is balanced properly. Make sure you have the right imbalance weight flywheel for your motor/year/harmonic balancer or the motor will vibrate itself to death in no time.
6 bolts. I got it to line up after moving it 4 times...
Threads Similar to: Flywheel installation
Flywheel installation BrandonxSD Classic Mustangs 0 June 20th, 2008 04:46 PM
flywheel help... terribleonexx88 5.0 Mustangs 4 May 1st, 2008 09:46 AM
flywheel invisa stang 5.0 Mustangs 0 November 29th, 2007 09:38 PM
Flywheel Help the real shocker 99-04 11 November 12th, 2007 03:48 PM
I need a new flywheel Cfears2000 Pictures 2 September 29th, 2007 06:27 AM
