Discussing Engine will not keep running?? in the Classic Mustangs Forum. Engoine is a 289 with mild cam and Edelbrock 500 carb, after a mild engine ...
Old June 22nd, 2008, 05:56 PM   #1
Engoine is a 289 with mild cam and Edelbrock 500 carb, after a mild engine compartment fire the engine was pulled to repaint the engine and engine compartment, i decided to replace the intake with a single 4 bbl tunnell ram and used the same carb, the wiring was all replaced and also a new set of hyd lifters, when i start the engine it will run for about 15 seconds and shut down, it seems to be loading up, sometimes it will puff back through the carb on the last gasp, sometimes it will start and run perfect for 15 sec and other times it will start and seem like it is on only a few cylinders, oil pressure is reading 50 lbs, float levels were checked and ok, engine ran fine before and i called Edelbrock to find out if the carb had to be rejetted for the tunnel ram and was told it was not necessary. any ideas??
Old June 22nd, 2008, 07:51 PM   #2
make sure the brass floats didnt melt the solder and sinling.
i sixing 200 six with 300 hp.
Old June 23rd, 2008, 01:37 AM   #3
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
Is the choke open?
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old June 23rd, 2008, 04:39 AM   #4
Choke is open and floats are not leaking, i am wondring if there might be a vacumn leak
Old June 23rd, 2008, 10:03 AM   #5
1967 Mustange Coupe, 200i
Sounds like perhaps fuel or air problem. How did you put the fire out? I have a friend who put one out with a powder fire extinguisher and she had to clean the carb and intake to get the dust out of it. I would suspect anything with a low melting point (e.g. vacuum hoses etc.). Also, perhaps the filter...just a though.
Old June 23rd, 2008, 09:21 PM   #6
Problem solved
finaly found the problem, after the fire i had to replace the coil and all i had was a Flamethrower coil for a Petronix ignition so i used it, the car i am working on has points type distributer and the high output coil was cooking the points, i installed a stock coil and new points and all is well, hope this helps someone else who might have the same problem down the road.
Old June 24th, 2008, 08:44 AM   #7
god show.congrats.
Threads Similar to: Engine will not keep running??
Can't get my new engine running correctly shurb125 5.0 Mustangs 14 March 2nd, 2008 03:55 AM
what can cause a rich running engine? kreil45 5.0 Mustangs 2 March 30th, 2007 03:22 PM
Continuing saga of a rough running engine mickchu V6 Mustangs 3 January 28th, 2007 09:53 PM
rough running engine mickchu V6 Mustangs 9 January 25th, 2007 12:28 AM
Anyone here running a stand alone engine mgt system? IcantDo55 The Clubhouse 8 August 24th, 2005 11:26 AM
