Discussing what heads would you recommend? in the Classic Mustangs Forum. for a 351 Cleveland? i plan on getting aftermarket 4v heads and i want the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2004 GT & 1972 Mach 1
Kessel Run @ Less Than 12 Parsecs
for a 351 Cleveland? i plan on getting aftermarket 4v heads and i want the valves to be huge and i want the heads to flat out breathe fire lol
2004 Screamin Yellow Mustang GT
1972 Yellow Mustang Mach 1 ![]() |
June 08 ROTM
1968 GT 500 Super Snake
12.6 @ 114.3
What RPM Range are you going to drive this in? 1500-3500? or you going to go 3500-6500?
If you go with bigger heads than 351C 2v head you need to raise the RPM range up. Just have to keep in mind what is the main point of this car. Driving or Racing |
i want it streetable, but mean as well, right now i cruise on the highway i 3K and it shifts a little over 4k when i goose it, how do i safely raise that? i notice my tach goes up to 8 but the needle has never touched 5
June 08 ROTM
12.6 @ 114.3
Do you know any specs on your motor?
Like mine is a 10.2/1 280/280 .512 LC 110 3:55 Locker Rear end Air Gap Intake. MSD W/6AL 750 Dual Line Holly This way we can try to tune you better, Than just saying you need heads. |
yeah maybe i can get a little more out of what i have first, this is all the info i could come up with, the stock specs should be right, but a lot of the sites i ran in to said different things so i dunno lol (thanks for the help btw!)
351 cleveland H Code (2 barrel motor) 8.6:1 4.00" X 3.50" 258/266 i think the rear end is 3.25 open diff. Edelbrock 600 P series 4 barrel carb dual point distributor the motor is stock except for the carb and dual point distributor
June 08 ROTM
12.6 @ 114.3
The first thing that to go fast is go with a 700/750 CFM Holly carb.
The Second thing be a New Cam. The Third is a Rebuild. New Heads will not solve your power woes. The carb is the quikest to get more now. Good Luck |
carb,cam,headers,rear.
i sixing 200 six with 300 hp. |
Undisputed Champion of MM
1966 Vinyl Mustang
too bad you don't have a windsor i want to know how those new edelbrock RPM XT heads work
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!! 1966 Ford Mustang w/ Black Vinyl top Mods listed in Garage |
700 CFM might be overkill for 2V heads under 6500 RPM.
I assume you have the Performer intake to go with the carb. Get a cam-lifter-spring kit like Comp Cams 268H or 270H Then get headers & 2 1/2" dual exhaust |
yes i do have the matching 4v intake, made quite a difference!
and i probably wont upgrade the carb for awhile but when i rebuild the motor i wanna build a streetable beast, and the 2v heads are gonna go...i love the fact its a cleveland but i hate the fact its from 72 due to the power decrease, sooo pretty much anything stock/restrictive is gonna go
#11 | |
June 08 ROTM
12.6 @ 114.3
280/280 .512 Lift LC 110 9.5:1 And it is a Beast. If you just Upgraded the Cam ![]() This high torque cams work very well on the street. Made for use with engines having a 9:1 or less compression ratio. They can be used in conjunction with most stock components. If you want Performance a 600 Edelbrock Carb is not the way to go. Edelbrock Start good but do not performe good. The Holly 700/750 Will Make a Huge Difrance. Trust me. Those 2 Things will make a big difrance. |
If you get the 4V heads you want the closed chamber type.
The open chamber ones detonation problems at higher compression ratios. The stock Ford valve train is the weakest link in a Cleveland. Get them machined for 7/16 rocker studs & and hardened seats. Use roller rockers and stainless valves. 4V heads like a dual grind cam like Comp's XE274H. Any bigger than that and you will need a Torker (Strip Dominator) intake & 750cfm carb. In the interm, you can get 4V headers & they will work with the 2V heads. |
Threads Similar to: what heads would you recommend?
| What do you recommend? | TheLookerTheWatcher | The Clubhouse | 14 | June 23rd, 2008 02:44 PM |
| Recommend Heads And Cam | sneezingfox | 5.0 Mustangs | 44 | December 24th, 2007 07:57 PM |
| What would you recommend? | brad03svt | 99-04 | 14 | October 4th, 2007 12:06 PM |
| What o\r hpipe do you recommend | jsando1 | Exhaust | 1 | May 25th, 2007 10:34 PM |
| Recommend one for me... | postie | V6 Mustangs | 6 | December 26th, 2006 10:51 PM |
