Discussing flexplate & transmission questions in the Classic Mustangs Forum. I have a 66 Mustang with an I6 that I'm going to do the ...
Old June 25th, 2008, 12:43 PM   #1
I have a 66 Mustang with an I6 that I'm going to do the V8 swap. I had a guy rebuild me a 302 that I believe is a 1978 block with the 28oz Harmonic balancer. It does not have a flexplate on the back and he also threw in a used v8 model C4 transmission.
The model number for the block is D8OE 6015 E3A and the balancer number is D62E-6316-A2A. The model number on the Transmission is DAOP 7006 AA. I couldn't find any information on the transmission, so I don't know what year model or anything about it. He also left the torque converter in it.
What I need to know is what flexplate should I use and will this transmission work with the engine as is, or do I need to buy a new bellhousing/torque converter. Also, will the flexplate/bellhousing on my I6 C4 work with the new V8?
Thanks in advance
Don
Old June 25th, 2008, 01:48 PM   #2
bell willnot work.trans may bolt to v/8 bell.
i sixing 200 six with 300 hp.
Old June 25th, 2008, 09:28 PM   #3
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
The D8= 1978 the bell housing from that should be fine.
If the tran has been useing in the last 6 month and was stored inside the torque conv should be fine.
The Flex plate you need to get this one from jegs. it is $76.99
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old June 26th, 2008, 09:25 AM   #4
yes.if the 78 tranny had the bell on it.it will work,but the i6 bell want work.
Old June 26th, 2008, 10:59 AM   #5
I pulled the transmission out into better light yesterday and the actual part number on the casing is D4OP 7006 AA. Does that mean the transmission was built in 1984?
Old June 26th, 2008, 11:23 AM   #6
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
Ford Year Numbers as follows:
A4 = 1944
B4 = 1954
C4 = 1964
D4 = 1974
E4 = 1984
F4 = 1994
G4 = 2004
www.Mustang1.Com
Threads Similar to: flexplate & transmission questions
aod transmission questions etony89 5.0 Mustangs 1 June 25th, 2008 05:59 PM
'95 SVT COBRA complete engine & transmission pullout midnightvenom Engine 12 February 23rd, 2008 12:14 PM
C-4 Flexplate novamastr 5.0 Mustangs 10 January 31st, 2008 03:03 PM
balancer&flexplate Fastpitchdad Want to Buy 0 February 21st, 2007 05:15 PM
Engine & Transmission Swap big_stroke 5.0 Mustangs 3 February 7th, 2007 02:28 AM
