Discussing Vacuum leak???? in the Classic Mustangs Forum. I replaced the intake gasket on my car a few months ago because it was ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1969 Mustang Mach 1
OLDNSLO
Vacuum leak????
I replaced the intake gasket on my car a few months ago because it was leaking oil, and coolant, and haven't had any problems since I changed it.
In the last few weeks my car has been staying idled up a few seconds after I stop before it settles into a good idle. I will come to a complete stop and it hovers around 1100-1200 RPMs, and then will slowly settle into a normal idle after I come to a complete stop. If I downshift into first, and let the engine slow me down, I will wait until it gets to 700 RPMs, push in the clutch, and it will jump back up to 1100 - 1200 and then slowly settle back down. It will also occasionally backfire through the carb when I give it gas. Except for the backfire, it kind of sounds like a vacuum leak to me. I don't think that new intake gasket is leaking, but I guess it could be. Could trash in the carb be casuing these symptoms?
![]() New ride http://www.superior-motorsports.com/...aig/craig.html Old ride http://www.superior-motorsports.com/...g/mustang.html old rides engine in new home http://videos.streetfire.net/video/4...285480b970.htm |
try spraying around the gakets with carb cleaner and see if the idle changes.if it dose check that area for a leak.the pop back could be timeing.or air fuel adjustment.
i sixing 200 six with 300 hp. |
1969 Mustang Mach 1
OLDNSLO
Thanks I'll try that. The timing and air/fuel have been the same since the engine was built so I don't really see them being off all of a sudden.
Could be something binding/dragging on throttle or dashpot linkages.
Also check vacuum advance on distributer & hoses. |
#5 | |
1969 Mustang Mach 1
OLDNSLO
The car doesn't have vacuum advance, and it doesn't have power brakes, so if it has a leak it has to be the intake gasket, the carb base gasket, or one of the rubber vacuum plugs on the carb.
1969 Mustang Mach 1
OLDNSLO
I sprayed carb cleaner around the base of the carburetor, and the idle surged, so I tightened it up a bit, and it still does it, so I'm going to get me a new gasket tomorrow.
1969 Mustang Mach 1
OLDNSLO
All fixed up. She runs like a new car.
Threads Similar to: Vacuum leak????
| Vacuum leak | smoke-em | 99-04 | 6 | January 11th, 2008 05:31 PM |
| vacuum leak? | Nev3rL1ft89 | 5.0 Mustangs | 1 | January 4th, 2008 06:52 PM |
| 96 Gt With A Vacuum Leak | sorrowfulkiller | Modular Mustangs | 38 | November 15th, 2007 03:17 AM |
| vacuum leak | DragonFreak | 96-98 | 1 | July 11th, 2007 10:12 PM |
| Evaporative Emission System Leak Detected (very small leak) | Juggalo_X | V6 Mustangs | 11 | April 25th, 2007 05:46 PM |
