Discussing To retrofit a fox pulley setup or SN95? in the Classic Mustangs Forum. I wanna use the HO roller block from my 94 Mustang 5.0 into my ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I wanna use the HO roller block from my 94 Mustang 5.0 into my 1968 Mustang coupe, and I want to utilize the 94 water pump, power steering pump, alternator & a/c compressor..
For the water pump, I'm gonna need to use a radiator with a different setup that will have the inlet connection at the driver's side -or inlet/outlet offset-. But for the rest.. I need to know -if anyone does- should I use the fox Mustang brackets or should I use the ones from my SN95? Which one will give me more room under the compartment? and are the p/s pump, alternator & a/c compressor common in those two late models, I mean will they fit on both 2 brackets without a problem? note from the attached picture for the fox engine that the location of a/c compressor is on the top of the p/s pump.. while in SN95, the p/s pump goes on top of the a/c compressor. The original setup in the 68 Mustang 289 is just like the fox ones. |
Just a small update.. the p/s pump is the same. the a/c compressor is different but I dont know if I can install the compressor for a SN95 on a fox body bracket. Does anyone know please?
Threads Similar to: To retrofit a fox pulley setup or SN95?
| Will my fox exhaust work on my sn95? | STREET6 | 5.0 Mustangs | 2 | June 7th, 2008 12:46 PM |
| any sn95 v6ers in nj/pa/del (M90 setup) | thetrooper31 | Power Adders | 0 | May 26th, 2008 12:55 PM |
| FOX rear end in a SN95??? | STREET6 | 5.0 Mustangs | 4 | February 19th, 2008 11:19 PM |
| wtb fox and sn95 parts | 92lxhatch | Want to Buy | 0 | February 10th, 2008 04:55 PM |
| SN95 spindles on a Fox? | Street Jesus | 5.0 Mustangs | 3 | January 12th, 2008 07:03 PM |
