Discussing Help With Piston to Valve Clearance in the Classic Mustangs Forum. Hello. I am a 19 year old college studen living on my ow. I recently ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Hello. I am a 19 year old college studen living on my ow. I recently found a great deal on a 92 mustang 5.0 HO motor for my 1967 stang. The problem is it has GT40P heads. They require special headers that they just don't make for 1st gen mustangs. Since i am on a budget aftermarket heads are out of the equation. Recently a guy i know from work found a set of 302 heads from a 1968 mustang. C8OE casting i believe. The heads have been ported and polished and now sport 2.02 intake and 1.60 exhaust along with all the valve train equipment for a hydraulic roller cam. All from comp cams. he wants 3 hundred as he is moving p to AFRs and doesnt need anymore. This seems perfect for me at this moment givin my budget but desire to still have some degree of performance. My question is, using the stock 5.0 HO cam pistons and 1.6 ratio rockers, will i have piston to valve clearance issues with the 2.2 and 1.60 valves. Is there anyone running a similar setup utilizing stock components with this size valves? I don't want to purchase if i'm giong to have to notch pistons. Any experience or advicew would be great. Thank you for your help.
Mike
Zippee is my step sister.
1990 Mustang LX
9.36@143 mph
You will have to mock it up and check the valve to piston clearance. Chances are you will run into problems with the 2.02 intake valve with stock 5 liter pistons.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft My daily driver has 16 cylinders and 4400hp @ 1000 rpm....
Slayer of Douchebags
yeah probably have to cut the pistons
RIP ![]() ΜΟΛΩΝ ΛΑΒΕ Political Correctness is a doctrine, fostered by a delusional, illogical, liberal minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. One Big Ass Mistake America |
Threads Similar to: Help With Piston to Valve Clearance
| Piston to valve clearance. | IcantDo55 | 5.0 Mustangs | 2 | December 30th, 2007 01:04 PM |
| 347? about rod & piston combo | And then some | 5.0 Mustangs | 14 | October 5th, 2007 10:54 AM |
| Piston to Valve Clearance | 94GTD1SC | 5.0 Mustangs | 6 | April 11th, 2007 03:39 PM |
| PISTON ? | 89GTCONV | 5.0 Mustangs | 1 | June 14th, 2006 09:44 PM |
| PISTON TO VALVE CLEARANCE FUNDAMENTALS | 173speed | 5.0 Mustangs | 0 | October 7th, 2005 09:47 PM |
