Discussing headlights in the Classic Mustangs Forum. When im driving at night, the headlights will flash on and off. Why is this ...
Old July 15th, 2008, 12:47 AM   #1
headlights
When im driving at night, the headlights will flash on and off. Why is this happening. When i bought the car, it only did if the brights were on but now it does it regardless. What should i do to fix this. Should i replace the foot switch or just the whole headlight harness?
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old July 15th, 2008, 12:49 AM   #2
You might have a ground problem. That happened to me had to trace the entire wire to find where it was.
Old July 15th, 2008, 12:50 AM   #3
where is it grounded or atleast where was it on yours so maybe i can check that first?
1965 Mustang
Old July 15th, 2008, 01:10 AM   #4
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
It is your Dimmer Switch, or Headlight switch, or a grounds.
The Ground for head lights is beside your voltage regulator right side of the radaitor.
My bet is on the dimmer sw.
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old July 15th, 2008, 03:11 PM   #5
Im going to go ahead and or the headlight harness and foot switch. That should fix the problem right.
1965 Mustang
Old July 15th, 2008, 05:26 PM   #6
i have seen the headlight switch do this when i changed to halogen lights.changed to updated switch and no more problem.
i sixing 200 six with 300 hp.
Old July 15th, 2008, 07:22 PM   #7
1sweet65stang's Avatar
1965 mustang 289 coupe
this happend to mine also and there was a break in the wire
Threads Similar to: headlights
Headlights HTK241 99-04 16 February 14th, 2008 04:39 PM
New Headlights EasyE64 General Tech 4 November 26th, 2007 11:10 PM
Headlights... 00GT MuscleBlack 99-04 39 August 3rd, 2007 07:21 PM
I got my headlights! MustangMatt96GT 96-98 40 May 24th, 2007 12:23 PM
new headlights burin_rubber Visual 40 April 12th, 2007 05:45 PM
