Discussing My 65's key wont turn. in the Classic Mustangs Forum. Hey guys I need a little bit of help. I'm going nuts right now ...
Old July 15th, 2008, 11:54 AM   #1
1sweet65stang's Avatar
1965 mustang 289 coupe
Question
Hey guys I need a little bit of help. I'm going nuts right now because when I put my key into the ignition it won't turn in my 65 mustang!!!!! I think it might have to do with the ignition switch but I wasn't sure if anyone else ran into this problem and they could help me out and tell me what they had to do. Yesterday I had trouble turning it and before that I had no problems at all. It seems kind of silly that it would be the switch because you would think it would wear down but I am not sure of anything. ANY HELP PLEASE!!!!!
(Don't make fun of me too bad )
Old July 15th, 2008, 12:20 PM   #2
03SonicBoom's Avatar
2003 Mustang GT
When I helped my dad restore his '66 he had the same problem. Something screwy with the switch. Turns out that if he put the key all the way in it won't turn. If the then pulls it 1/8"-1/4" out it turns no problem. Try putting it in, w/ light pressure try to turn it and slowely pull it out a little.
If that doesn't work, replace the ignition.
Old July 15th, 2008, 12:34 PM   #3
Problem solved thank you so much.
Old July 15th, 2008, 02:27 PM   #4
All Throttle with a Bottle
MustangMatt96GT's Avatar
12.91@105.29 @ 5800 FT
mine does the same thing... pull it out slightly and it works. BTW the orginal keys dont require this, just the "newer" cut keys.
We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
Old July 15th, 2008, 08:07 PM   #5
i have what i thought was orginal with the rectangle top with Ford printed on it but i did none of the restoration and bought the car from someone that did the full restoration and his spare key that he got cut at a store works perfect with no pulling out a little to start. Im not sure what the problem is but i do need to get some spares of the one that works perfect. Im kind of new to this since i just got the car last month how do u guys get those signatrues made?
Old July 18th, 2008, 01:00 AM   #6
I make my own in Photoshop... but some of the guys may do it for ya if you post it in the Chopshop section
Old July 18th, 2008, 10:18 AM   #7
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
Made my sig with Adobe
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old July 19th, 2008, 01:14 AM   #8
ok thanks a lot it wont work now though.....idk wth the problem it is showing that its set up but the damn thing obviously isnt down there....is it?
Threads Similar to: My 65's key wont turn.
AC wont turn on!!!! blackhavok 2005+ 5 February 17th, 2008 11:00 PM
turn on without key notsoslow50 5.0 Mustangs 17 August 3rd, 2007 10:59 AM
key broke in doorlock.. car wont start BULLDAWGSFAN52 General Tech 7 July 8th, 2007 11:32 PM
Key Turn Issue! Please Help yellowstang98 Modular Mustangs 5 May 9th, 2007 11:58 AM
Broken Key Cylinder removal - Key will not turn, Ideas? Murago 5.0 Mustangs 6 June 21st, 2006 11:35 PM
