Discussing 289 to late model 302 swap. in the Classic Mustangs Forum. I am going to swap my 289 with a 93 302 in my 67 mustang. ...
Old July 15th, 2008, 06:35 PM   #1
I am going to swap my 289 with a 93 302 in my 67 mustang. All all my parts from the 289 intake manifold, oil pan, timing cover fit? Also is it possible to keep the serpentine belt setup from the 302?
Old July 15th, 2008, 08:03 PM   #2
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
everything will swap. but if you use the serpentine set up you will need to change your radaitor kneck to the other side on the bottem one.
If you use the serpentine set up you will need to use the 93 water pump.
<a href=http://Mustang1.Com target=_blank>Mustang1.Com</a>
www.Mustang1.Com
Old July 16th, 2008, 04:21 PM   #3
As far as the radiator, do you know which one will fit or if they made a specific radiator for this swap?
Old July 22nd, 2008, 07:06 PM   #4
u can swap most of the stuff but without buying a special harmonic balancer the belt system will not work the 81 &later 302 had a 50 oz balance and the 80 back all winsor family engines had 28 oz stock balance
Old July 23rd, 2008, 10:18 PM   #5
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
I use the 1969 4 Row for a 351. The bottem kneck is on the driver side.
and you can use the 1968 radator clamp set up. quik and easy.
www.Mustang1.Com
Threads Similar to: 289 to late model 302 swap.
Late Model Restoration thepizzle44 99-04 10 June 5th, 2008 10:08 AM
95 mustang gt vs late model tibron jeffmarble Street 38 April 28th, 2008 09:41 PM
Late model buckets for a '68 6T8coupe Classic Mustangs 3 June 7th, 2007 02:14 PM
Late 04 Model kanniiee V6 Mustangs 3 September 26th, 2006 11:37 PM
